  New Posts New Posts RSS Feed - Oil Gauge on Dash
Oil Gauge on Dash
AllenSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllenSki Quote  Post ReplyReply Direct Link To This Post Topic: Oil Gauge on Dash
    Posted: June-29-2011 at 1:05am
I have a 2005 AIr Nautique, recently had engine replaced, after getting it back the oil and temp gauge on the dash are not working, all the others are. It's reading oil psi because I can see it when switch from hours to oil psi on dash. I know it's probably wiring but just thought I would ask. Was hoping I could fix myself without having to take back out of water and back to shop.
Any suggestions to check would help.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2011 at 1:35am
Check fuse or breakers. Check wires to the guages. The saying here on the site is 90% of electrical problems are bad connections or bad grounds.
I hope this helps,
Donald
