  New Posts New Posts RSS Feed - Airguide Speedo Cleaning
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Topic: Airguide Speedo Cleaning
    Posted: August-12-2005 at 6:32pm
What is the best way to clean (flush) the pick up tubes to remove any debris that could be clogging the lines? I have tried the fast reverse method with limited success.
mrese View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrese Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2005 at 9:00pm
Use a small drill bit (1/16")with your fingers and gently spin it upward at an angle into the pitot's pickup hole (end of the black thing under the boat) It will pull out any debris.
JAG459 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAG459 Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2005 at 11:08pm
If you have a pressurized air source available just pull the tubing off of the pitot tube and blow air back through it (the pitot not the tube).
skyhawkflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: August-13-2005 at 7:42pm
I've been using a drill bit for years, works every time and plenty of room for it in my glove box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: August-14-2005 at 6:27pm
Thanks, I will give it a try this week
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 1:04pm
I keep a syringe with a small piece of rubber tubing on the end ( same size as what's attached to the pitot) and use water pressure to discharge the blockage.Works 98% of the time then just a small straightened fishhook to dig out any debris if backflushing didn't work. Worst case is I'm out of a $.03fishhook instead of a $2 drill bit.
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 6:04pm
A paper clip works well, too.
Bob Ed
83 2001
Kevin's '79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin's '79 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 6:35pm
I have always used a safety pin. I keep one clipped to my keychain and can take it off and use it whenever needed and then put in back on.
