  New Posts New Posts RSS Feed - Negative battery cable Hot!
SMay81SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Topic: Negative battery cable Hot!
    Posted: August-15-2005 at 2:54am
Quick question guys, my 81SN this weekend had some electrical issues.
The negative battery cable is very hot. I know this because I burnt my fingers on it. Something seems to be shorting out.
My battery is fully charged, all belts are tight, I clean the terminals usually before I start the first time so I always have a good connection.
But this weekend after running around the lake for about a hour and stopping then restarting the started stayed engaged, I then tried to turn off the ignition switch, which didn't work, then pulled off the positive batter cable because the negative one burned my fingers.
Any ideas what I might have going on? The starter and solenoid are new, ignition switch new. Everything has been working fine. I only have the problem of a hole in one of my exhaust manifolds which will be replaced this coming fall.
Please give me some ideas. Thanks!
SMAY-81SN
Scott
Our 94 SN
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 2:41pm
Do you have a deep cycle or cranking battery and what is the CCA rating? If it is a deep cycle replace it if it has less then 650 CCA replace it. Check your starter for worn brushes that need replaced causing more current draw from the battery. Do you have marrine grade cables? if they are automotive get rid of them, whats the wire gauge? 1/0, 2/0 if it's 4 or 6 gauge wire get rid of them and replace with heavier gauge wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 2:55pm
I can't recall what the battery is but I had it put in by Southwest Correct Craft last year. (Boat is at the lakehouse an hour and half away) They also put a new starter in last summer. I replaced the battery cables about 6 years ago, they are 2 gauge wire that I bought from a marine store...I believe they are marine grade. The negative one though is corroding at the end where the connector is to connect to the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 3:54pm
look into some new cables 2 gauge wire is small and the added corrosion isn't helping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SMay81SN Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 8:25pm
Well the 2 gauge wire is bigger than the orignal cables...its almost a 1/2 inche wide and the cable looks good except the very end. I still don't think this is what is causing the negative terminal to be so hot.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 8:34pm
Well, if one connection is hot, and the other isn't, the problem is most likely the hot connector, because what comes out has to go in, and if something else was causing it, both would be hot. Unless you have a 'tricity leak.
River Rat to Mole
mrese View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrese Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2005 at 11:20pm
I may be wrong, but it sounds as though you have 2/0 size cables. That is a good size. Without knowing anything else, I GottaGO with GottaSki. The corrosion on the terminal more than likely has spread futher into the cables, even though it may Look Good. As more electicity passes through the restricted and corroded wires, it heats up.
Bhedbloom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bhedbloom Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2005 at 12:32am
Just an FYI:
I had a bad starter this year and it really heated up the wires. Burned my fingers hot! The starter was pulling way too much cuurent.
Happy Boating!!!
Barry, South Carolina
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrese Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2005 at 3:53am
Both pos and neg cables burned your fingers or just one?
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2005 at 10:47am
My vote is to replace the cable. I suspect corrosion exists within the cable near the terminal where it cannot be seen (reducing the effective wire diameter at that point). If the heating was caused by overcurrent both cables would be overheating. (Assuming the cables are the same size.)
ty3724 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ty3724 Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2005 at 9:00pm
I second that same problem I cut the end off put on a new lug same thing hotter than SHi changed the cable and away we went the corrosion had crawled up the cable and couldnt see it
