this fell out from under the dash....what is it? |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Posted: July-10-2011 at 6:49pm |
Steve
2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer Former CC owner (77, 80, 95, 88, all SNs) Former Malibu owner (07, 09) |
sweet77
Gold Member Joined: January-06-2011 Location: Florida Status: Offline Points: 666 |
Looks like my check book and my wallet ill send you my address...
On a more serious note.....I have no clue |
Swatkinz
Haston, sadly, the wallet nor checkbook wouldn't do you much good. |
Steve
GottaSki
You must have a rotary steering box.
That appears to me the tube that the steering cable feeds into as it exits the helm. Without it, your knees will likely get greasy next ride out. |
River Rat to Mole |
Tom is correct. It's the protective cover for the "dead" end of the steering cable.
Swatkinz
thanks guys, I think I see where it slips over the greasy thing. What is supposed to hold it in place?
Steve
emccallum
Platinum Member Joined: August-08-2006 Location: Clarks Hill SC Status: Offline Points: 1084 |
friction fit into the helm. Mine did the same thing. I think I put some duct tape around it.
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
That's Donald's Bong Tube !! For his Bear Funnel
DrCC
It's the nozzle from an Industial Strength Preparation H tube.
Swatkinz
was one heck of a rough day. In seriously rough water we were forced to slow down (a kid, not mine, wouldn't stay seated) in unbelievable chop and took 2 waves over the windshield. kept going as we had no other option. that tube thing fell out from under the dash, the horn stopped working (I'm guessing b/c of water intrusion at the bow vent), and the antenna cable somehow unplugged itself from the back of the radio.
I must be spoiled as this was my only trouble (knock on wood). Thanks for the replies fellas. Hope you all are enjoying your summer |
Steve
DrCC
If you have the metal or plastic nut. You might have to melt a flare on the tube to keep it in place.
Swatkinz
it's a plastic nut melt a flare? i don't follow Ernest's suggestion involving duct tape seems reasonable although I'm sure not "original" can you explain the flare melting thing? I don't want to overcomplicate this, but if flare melting is relatively easy and a better fix, I'm all ears. |
Steve
DrCC
Take the nut off.
Melt a flare-ish or mushroom-ish shape to one end of the tube. Slip the nut over the tube and back onto the helm. Sounds like a not fun boat ride. |
Morfoot
Steve, Al is wanting you to "flare" the end of the tube that's under the nut. Basically expanding just the end of the tube so that it wont slide out of the nut. Take the nut off the helm and slide it over the tube as you wont be able to do so after you flare the end. Heat up the tube with a hot hair dryer or boiling water then try expanding the end of the tube with a socket just slightly larger than the tube itself. Once you force the socket in the tube wiggle it back and forth "expanding" the end of the tube. Once the plastic cools off remove socket then slide the plastic nut back down to see if you "flared" the end of the tube enough so it won't slide out of the nut.
OR: Use some teflon thread tape and wrap the end of the tube several times so the nut wont slip off the end. Give me call if you need some help |
Swatkinz
Steve
Swatkinz
I see...that makes perfect sense. thanks for the help guys. |
Steve
TheChad1976
Groupie Joined: October-12-2009 Location: Jacksonville FL Status: Offline Points: 44 |
I just ordered a new one of these for $8 dollars from skidim.
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Good idea with the flare. I am always trying to get mine to stay on there. Good post Steve. We had a pretty rough ride back to the ramp a few weeks ago when a big thunderstorm blew in. Not so much fun!
Hope you guys are having a fun summer. Its flying by! |
1973 Skier |
