  New Posts New Posts RSS Feed - Water Stains on my paint.  Suggestions?
MontanaSport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Topic: Water Stains on my paint. Suggestions?
    Posted: July-11-2011 at 11:09pm
My Sport with black N lines up and down the hull has some bad water drop stains on it from previous owner's use that I can not get out and do not want to use something harsh that'll dull it. Is it possible to get it off without hurting my paint?
Turn Me Loose, Set Me Free
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2011 at 11:20pm
MS - your "paint" should be gel coat unless your boat was actually painted by the previous owner. None the less, the steps are similar, though gel coat will be thicker and more durable, which also means a bit harder to polish.   Look for the "wetsanding threads" and you'll get an idea of what to use if the gel is really bad.   if you just have hard water spots, the polishing steps are needed, but maybe not the sanding.   try the lighter steps first to avoid doing a bunch more work than necessary.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2011 at 11:23pm
I'd start with 3m Rubbing compound, then move up from there.
Look for a thread I started called "which 3m Product"
Everything you need to know is in there thanks to all the guys here on the site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2011 at 11:31pm
3M marine polish/wax.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2011 at 1:08am
Guys thank you. No it wasn't painted by the PO but it does have a small metallic gold stripe running along between the black and white. Thanks for pointing that out. I have tried vinegar, a small test of CLR, a test of acetone and it just laughs in my face.
I'm going to get some of the 3M stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2011 at 12:57pm
Hey is the 3M polish/wax that was mentioned the same stuff as 3M Finesse It Marine?
I just called corporate Nautique and was told to go with that. The guy also mentioned he'd heard of toilet bowl cleaner but hadn't tried it.
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2011 at 1:38pm
Yes, Finesse It is the wax/polish. That would be normally be the last step. The previous step would be 3M marine rubbing compound and before that, wet sanding at increasingly finer levels. As Storm34 said, move up from the Finesse It to see what is the least you need to do to fix it.
My guess on the toilet bowl cleaner is as a replacement for On and Off, which is a hull cleaner designed to remove buildup of "gunk" on the hull. This is not what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2011 at 1:57pm
Careful- Finesse-it II is a polish, and a great one at that. It is not a wax, and will not protect the shine of the boat. I would highly recommend a good coat of wax as a protective layer for your "last step".
drtybrdy9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drtybrdy9 Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2011 at 8:16pm
If I wax the boat enough will there ever be a need for polishing or wetsanding? Or can we only slow down and not stop oxidation regardless of what we do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2011 at 9:22pm
It's all in the eye of the beholder.
I am under the impression that if properly wiped down, washed, etc regularly and after using, there's no reason why you couldn't basically prevent oxidation. I guess another thing depends on if you dock it, what kind of water your boat is in and other environmental factors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2011 at 8:55am
It's the UV light and not the water that causes the oxidation.
skyway2k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyway2k Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2011 at 11:05am
I just used a 50/50 mixture of vinegar and water with a squirt of dish soap in a spray bottle to take off the water spots on my hull from the PO. It worked like a charm and after that I put a good coat of wax on. The boat looked wonderful after!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MontanaSport Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2011 at 12:09pm
so if you keep it out of direct exposure to sunlight, obviously when not in use, it could minimize oxidation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2011 at 1:05pm
Yes and the reason some will go to the extent of having full below the waterline covers. Even if the are on a covered boat lift, the sun comes in and gets the hull sides.
