1984 ski Nautique, electrical questions. |
Author | |||
Maximal691
Senior Member Joined: July-26-2011 Location: Saratoga ny Status: Offline Points: 109 |
Posted: July-26-2011 at 12:42am |
Hey guys, I've been lurking these boards for a while and finally registered. Anyways, I bought a 84 2001 that wasn't running. The boat had been sitting, so I charged the battery and went to see if I could get it to crank. No luck. I dont know what the switches are too because the lettering is worn off, but when I turned them on I got it so I had a constant alarm noise, even with the key removed. The volt gauge shows no volts, except when I go to crank the engine over, the volt meter will move just a hair, not enough to show volts, but enough to show that it moved. The horn works, I didnt hear the bilge turn on and it doesn't have any lights for me to check. Just for fun I replaced all the fuses, I put in 25amp fuses, is this ok? I'm guessing that this is some sort of ground issue. Does anyone have any suggestions on where I should start checking connections or what it might be? Also does anyone have any pictures of what the switches are so I can label mine? Thanks a lot guys, I would love to get this thing in the water before the summers over.
not given,
Did you check to see what the voltage is at the battery? (use a volt/ohm meter) If the boat has been sitting for a extended period and the battery was competely drained, then it's shot. Pulling a battery down below about 10 volts will permanently damage it. Are the battery terminals clean? Did you use a wire type battery post cleaner on it and the cable terminals? "just for fun" replacing fuses???? If they Ohm out good, why? Yes, do not indiscriminately replace fuses without checking the original amp rating. If you have an electrical problem, the larger amp fuse will not give you the protection needed. |
Maximal691
It was missing fuses, so I replaced them to see if it made any difference, since they were missing and I couldn't check to see what the original rating was, I'm asking if 25 amps will work, will they? I used another, good battery to trouble shoot while the one from the boat charged. I cleaned the terminals as well.
Yes, they will work but, as stated:
So, what was the voltage at the battery? |
Maximal691
I didn't have a volt meter, but the battery took a charge, and the other battery I tried I know is good.
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
I have an 84 2001 and just bought new fuse holders and fuses. Most are 15 and 20 but I don't remember what is what. I can let you know later, if it is not raining tonight.
Going from memory top to bottom it is: Nav something... Bilge Blower Ignition A PO also wired in an inline fuse on my ignition for some reason... I'm in Albany with an 84, looks like I'm a bit ahead of you on the project. I've been able to use it 3 times so far but still have a bit of a transmission fluid leak. |
Maximal691
I'm going to just trying reconnecting all of the grounds and check all of the connections. Ny nautique are you goig to be redoing your stringers this winter by any chance?
When you get a chance, get one. A basic meter is only around $25. You'll find them real handy for trouble shooting and you won't become a "parts changer". Very usefull around the car and house as well. |
Maximal691
Yea I Have a multi meter, I just didn't have one with me. I'm going to go back today more prepared. I was just wondering if there's a common problem with these boats or if there's anything extra I should be looking out for. |
The typical problem is dirty corroded conections and undersized ground and feed wiring up to the dash. You may also find brittle/broken .250 quick connect "sta-cons" under the dash as well. |
Maximal691
I keep blowing what I think is the bilge fuse? 3rd switch down from the top. Would this be the cause of now start or power?
ny_nautique
I was right about the fuses on the left panel. And I still have no idea what the 2nd one down is for. The right, you probably know, is the horn and then the 12V. Yes, I am planning on doing the stringers this winter, as long as I have a heated space for it. Still working on that part... Jeff |
ny_nautique
Yes, this is the bilge fuse. No reason that would cause it to not start. I'm guessing you just have bad contacts. When was it last run? |
ny_nautique
One other thing... what do you mean by "alarm noise"?
I have an issue when I attempt start it after it has been running, it won't do anything. I've found that keeping it in gear (not pulling the neutral pin) and going from forward to reverse will allow it to "click" and start. I then attempt to start, put it in neutral, give it gas, and I'm good to go. I have to check the morse to see where the problem is. I've never looked at my gauges when I do this but maybe you could try this. Make sure you don't run it without water though. Assuming yours is like mine, you can put a hose in the water strainer (the one with the wingnut on it in the engine compartment) in the hole going towards the engine. |
Maximal691
After today I think I found out the alarm noise is from the depth gauge? The boat was last run last summer, and then the previous owner had engine problems. I'm sure the engine will probably need to be rebuilt, but I still want to get the electrical stuff figured out anyways. Ny Nautique my email is maxmincher2@yahoo.com, shoot me an email and we can talk about stringers.
tomegtt
Newbie Joined: July-29-2011 Location: florida Status: Offline Points: 4 |
Maximal691
I went through all of the connections and I got all the gauges to work and the depth finder to turn on. Thanks for the help guys.
jiangjiang
Newbie Joined: August-01-2011 Status: Offline Points: 2 |
really want to reduce the number. Because they are not an officer,
pad case saleingno health insurance card, the state does not reimburse them. Unlike those of national cadres, are spending the country's health costs, the hospital thinking about how to diagnose,keep stylish how to they can check? Because these medical expenses were reimbursed by the state, they have plenty of money, just to check what, for them, no matter how much harm! |
asdasd123
Newbie Joined: August-10-2011 Location: asdasd123 Status: Offline Points: 2 |
As the most important event in a woman's life, wedding is bound to have an amazing wedding dress to steal the limelight.
bridesmaid dresses bridesmaids dresses junior bridesmaid dresses plus size bridesmaid dresses Evening Dresses sale |
asdasd123
