Wakeboard tower/extension pylon?? |
Guests
Guest |
Posted: November-11-2011 at 12:10pm |
I need some advice from other members, as barefooter and wakeboarder I would like to add either an air tower or fly high pylon to my 89' Ski Nautique. I really don't want to put the holes in my boat but im unsure if I will get the stability from the extended pylon. Also am I risking an potential damage to my boat by putting an extension on the stock pylon (leverage pulling against the stock pylon). Any advice?
Brian |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
We love the Fly High for barefooting, wakeboarding, sky-skiing, wake surfing, etc. We use one for pretty much everything by trick and slalom. Any boat we ski behind a decent amount has one.
A tower adds a lot of functionality, but Im not crazy about the look or having to drill into the gel. |
Guests
Guest |
Thanks for your advice! I will invest in one this coming summer. Love your fleet of correct crafts. I have a similuar addiction. Just bought a place on the Hamilton Res in Holland,Ma, I'm eager to start collecting!
SN206
Grand Poobah Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
SN206
My boat.
Guests
Guest |
how do you like the extension on the tower? I wakeboarded on one this past summer the boat would move when i would cut but i got great air...maybe i need to loose weight haha
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
Watch craigslist and this site,used fly highs come up frequently in the 200 dollar range.
1987 Ski Nautique |
SN206
Think I tried wake boarding once even though I have a couple. I'm usally in the curl of the wake when I foot, so pulling the boat to the side is not really an issue. It does add some weight and can be cumbersum if you have to lay the tower down everyday, but for the most part it's a great option to have for footing and teaching other disciplines behind the boat. |
Guests
Guest |
I actually did pick up a used one..for free! but Barefoot international told me not to use the rachet strap(home depot)system because they might flex due to the nylon. But as I sit here looking at all the other boat on this site that doesn't seem to be the case apparently...also i was looking for a sleevefor my origional pylon which is impossible to find, I will probably use tube socks and duct tape so the origional pylon is preserved.
MI-nick
Gold Member Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 810 |
since you got an extended pylon for free, it's really a mute point now...but...tower is the best functional solution. more stable, no need to put up/take down every time, better for space in the boat (no cable to dogde, can add board racks), and you can't backflip off an extended pylon...but, i digress...of course, i only wakeboard and think the flight control style towers look perfect on 2001's...
As far as I can tell, I'm not quite sure...
OverMyHead
Brian, if you have the cables but not the harness, I know some members have found replacement harnesses. I could see an improper harness allowing too much flex of the pylon mount. I did not fully understand your pylon issue, can you post some more information.
1987 Ski Nautique |
Guests
Guest |
I was just up in the air on if i should get a tower or a pylon...i was given a pylon but it did not have the ctraps...barefoot international stated that straps needed would have flex in it because it is made from nylon, and the cable system is the safest way to go. I was just looking into what other members though on this topic. I know there are members who would discourage putting the holes in these older boats.
SN206
If you have a bow noose, the ratchet straps will work just fine. The bow noose is a must have though to protect your boat and not damage the gel around the lift ring.
