  New Posts New Posts RSS Feed - Wanted: Observer Bench Seat
Keith View Drop Down
Admin Group
Admin Group
Owner / Operator of CorrectCraftFan.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: Observer Bench Seat
    Posted: March-26-2004 at 1:35pm
I'm looking for an authentic Correct Craft rear-facing observer bench seat that will fit my '79 Mustang. The '79 Mustang has the same beam (76") as that era Ski Nautique so those would fit.
Please e-mail Keith@CorrectCraftFan.com.
Thanks,
-Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
ScottZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2004 at 2:45pm
Check with Dennis at Mid West CC. He has the frames and foam cushions.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2004 at 7:26pm
I called Dennis. He has some non-hinged frames but no bench seats. I'm still looking from some hinged frames(not sure if these came in the '79 but I need access under the bow) and/or a complete bench.
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2004 at 8:09pm
I'm pretty sure the hinged frames were not used until the 2001 SN went into production. You could probably add some hinges to the standard frames.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2004 at 9:08pm
It's actually a reversable bench seat for the '79s (if I read the text right in the reference section correctly). Kind-of a pain stepping over the seat to sit though when it's facing forward. You still have access to the bow for storage, all you have to do is reach around from the drives seat and it's no problem or slide it forward. If you pretty hand an can weld Aluminum hinges would be real easy to add to the frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2004 at 9:10pm
Ooohh that was bad.
If you are pretty handy and can weld better than I can spell or write.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2004 at 9:04pm
The hinges on my 85 SN are bolted to the frames.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2004 at 4:48pm
Does anyone have the measurements and/or patterns for the bench and back?
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2004 at 12:01pm
I can measure mine tonight. Do you have the skins or do you plan on buying them or making them your self? If you are going to buy them I would call dennis at mid-west C.C. and you can use them as a pattern. They back is a trapizoid shape with rounded corner and the bottom has a couple of cut-outs on the rear. Also the foams are tappered.
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2004 at 3:29pm
79Nautique,
Can you take measurements and send them to me? I have a teak covered battery comparment and cooler in the floor between the front seats. My guess is that one of the bench seat brackets would land right on top of the teak cover. I need to determine how commited I am to having a second observer and go over my options.
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
yellowdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowdog Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2004 at 6:26pm
Keith,
I also made a teak cover for the battery well on the '78. The seat frame just misses the cover. If your cooler rises vertically from the battery cover, it will interfere with the seat overhang.
Thought about moving the battery into the bow area ala tryan and using the old battery location for a cooler, but got lazy. Maybe next winter! Let us know how it turns out.
Don
Caretaker of the wife's '78 Ski Nautique
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2004 at 7:10pm
The cooler is another hole in the floor, same size as the battery compartment, to the front (bowside) of the battery compartment - they share the same double hinged teak cover.
-Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
nauti girl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nauti girl Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2004 at 7:14pm
My '78 Martinique doesn't have a cooler, but I have a 2-passenger observer bench and the battery box is barely squeezed in between the seat mount and the bow enclosure.
Nauti Girl
--I think my husband uses his own login now!
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2004 at 6:37pm
Does the observer's bench seat brackets in the late '70s Nautiques look like these where the driver's side bracket is set in (i.e. to avoid where the cover to the battery box is located)?
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2004 at 8:02pm
Keith
my seats about like that but do not hinge. My bracket is moved closer to the center line and the base of it is shorter for that brace. On mine there are plates that mount to the floor(three long, one short) with two studs sticking up from them, then the bracket for the seat is slotted and there are big knobs that screw onto them that allow you to slide the seat back and forth or turn it around so that you are facing forward instead of rearward. I think this set-up would work nice if there was a brace on the overhang that would support the outside of the seat.
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2004 at 6:39pm
Ideally, I can buy a complete observers bench seat but I'm having a hard time finding one.
I think making one is something I would give a try if someone could send me the measurements of the seat and back.
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2004 at 2:14am
Still looking for a complete seat. Does anyone have one out there from 1975-1980?
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
