how to flip over boat for bottom work |
kman
Senior Member Joined: May-30-2008 Location: United States Status: Offline Points: 161 |
Posted: March-05-2012 at 4:05pm |
I know some have done this before but can't find a post. My friend is going to re-gelcoat his entire 74 South wind 20. One of the previous owners thought it would be a good idea to paint the entire bottom of the boat!
So. I work for a sign company and we were thinking we could pull the engine with the crane truck and then lift the boat with straps fore and aft, and gently roll the boat over in the straps and lay it back down on some wood runners across the trailer. At least my crane operator thinks he can. Does anybody have a better or easier way to rotate the boat like a rotisserie? And I am assuming leaving the engine in would be catastrophic. Thanks - kirk |
Kirk
1976 Southwind 20 Eagle Mountain Lake Fort Worth |
Kirk,
Ideally you should have two slings attached to 4 hoists. A hull being heavier at the bottom does not simply roll over. |
kman
That looks like what we would be doing with the crane. A spreader bar at the top with two straps. My crane operator says he has rolled heavy signs before...
What about the engine removal. That must come out first, right? |
Kirk
You need two spreader bars and two cranes. The straps get clamped off to the hull and then one side is raised and the other side lowered. Yes, the engine needs to come out. I also suggest pulling the fuel tank. |
uk 1979 part2
Groupie Joined: April-30-2011 Location: UK Status: Offline Points: 71 |
You can use a fork truck with a spreader bar its not the best way and you need to be real careful have some old tyres on the floor under it too, be safe
lets have a go 2
storm34
I'd be hesitant to lay the hull directly on the deck.
Instead, I'd support it from the stringers like seen below. Simple to make and keeps the deck from cracking under the weight of the hull. |
Scottie m
Groupie Joined: March-03-2012 Location: St.Paul MN Status: Offline Points: 73 |
I would also hook a chain fall on it to control the rotation better
From where to where? |
Scottie m
Hook the fall above the pick point
Then hook the chain to a choker that's choked around the boat.. I would only attempt this if you have heavy rigging exerance! Things could go really bad quick |
