  New Posts New Posts RSS Feed - lost steering
lost steering
 Post Reply Post Reply Page    <12
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 12:38am
The cable replacement was in my winter to do list .....didn't hold though
<a href="">1992 ski nautique
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 4:54am
not to worry, it made it's way to the top of the list
This is the life
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 8:54am
That was funny sorry!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 6:03pm
I have all out including the cable, went easy, what i don´t see in my set up is no steering block/stop or similar.
Should the rudder have some kind of stop to prevent is from going 360?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 7:56pm
Nope, once you attach the cable it can't go 360.
The "block" is the attaching point/ support where you bolt the cable/Housing to just in front of the rudder, then the end of the cable gets bolted to the rudder arm.
Just like the one you took out ---I think. LOL
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 7:58pm
the steering "stops" are the cable fully extended and fully retracted.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2012 at 8:04pm
make sure you are getting the rudder to turn to right and left pretty equally before you button it all up.
you may end up adjusting this a little bit if the prop rotation makes it turn tighter one way than the other.
I set mine where they are equal and it seems fine there for me.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2012 at 1:58pm
Bought a rotary system made locally along with the cable, with a Uflex tilt column, for $340 wich seems to be a good price. It looks pretty stout. Could have been cheaper if I opted for a fixed column though...
now I need to make some time to install it
some pictures of the helm and column...
the cable rolls inside the helm, so the cable end does not exit from it like other systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 5:02pm
geez that MF cable is hard to pass...went today: Cable 1 Kapla 0...
Looks like I will need a second set of hands and lots of soap...
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 5:48pm
Be sure to send us the pictures
On a more serious note, are you have trouble with routing it through the hull?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 5:53pm
Yep, even though I left a guide rope to pull the new cable in, its getting stucked somewhere...But hell if I was able to pull the old cable out, I guess eventually I will be able to slide the new one in. More time and patience will be needed...Hope round #2 will be in my favor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 5:58pm
Hmmm, I ran into this with wiring. Sometimes if you can form the connection between the guide rope, and the wire/cable you're pulling, into a little arrow with duct table, you be able to get thru better.
If the "head" of the thing you're trying to pull is too chunky, it's bound to snag. A little bit of pushing from the other side would help to, hence the extra set of hands I guess.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 7:13pm
electricians use a device that looks like a chinese finger trap.   Might help in this situation...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 5:13pm
round 2: kapla 2 cable 0! winner kapla!
lol went with the help of my inlaw this morning,
with the second set of hands cable went easely.
Then install went pretty straight forward, had to drill new holes in the dash for the new column, old ones got covered below the wider column so no ugly visible holes in the dash.
Went for a test drive and works fine. Still need to do some adjustment on centering the wheel.
Steering goes smooth, I can turn to both side with ease, but a little of more effort is required when doing rigth turns. Is this something to do with the prop wash? normal or needs some attention?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 5:20pm
Not sure, mine seems to take a lot of effort coming out of turns at speed. I'm thinking it's more the rudder, but I've never disconnected it from the cable to see. Is your rudder port greasable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 6:26pm
when the cable is disconected the rudder moves freely, at least on the dock, not sure how it would behave underway....
no grease and no packing, it was modified and its sealed with 3 rubber O-rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 6:29pm
Hope Pete doesn´t take this bad....
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 6:37pm
some pictures
drilling
