  New Posts New Posts RSS Feed - Pin stripe
Pin stripe
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Topic: Pin stripe
    Posted: March-30-2012 at 1:03pm
The 1/2in wide pin stripe under the fuel over flow is missing(about 4in) There are 2 other small places it could be touched up too. I had to buy 150ft roll of 3M Pale gray to match it.
So should I cut the edges off square with an exacto and add in a new peice with about 1/4in over lap? Never touched up pin stripe before.
                                                     Thanks -
- waterdog -
78 Ski Tique
bbishop1974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2012 at 3:30pm
I have seen alot of touch up jobs,some good some not so good.try it and see if you can live with it.if you can i'll buy the rest off you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2012 at 12:11am
Brian,
I talked to the guy at the body shop. He they always use the whole roll and splice the 1/2in over lap and be sure to remove the clear plastic thats on top of the color.
I'll have it done before the end of April (White Lake)
I'll let you know. How much do ya need?
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2012 at 1:11am
i'll be doing the whole boat eventually,doing stringers now,then flipping and doing gel.so i'll be ready sometime next lifetime.just kidding,e mail when your done bbishop1974@hotmail.com.thanks
