  New Posts New Posts RSS Feed - Bilge pump barely working need advice
scottsims1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottsims1 Quote  Post ReplyReply Direct Link To This Post Topic: Bilge pump barely working need advice
    Posted: May-17-2012 at 11:12pm
So my 05 air 206 bilge pump has something wrong with it. Before I replace it was going to ask the experts for advice. When I turn it on via dashboard it spins for about 5 seconds then turns off. I checked the trap and it is clean. I have about 4-5 inches of water in the hull to the point that the entire billie is underwater and the battery box is about an inch from having standing water. Any advice before I yank it and replace it???
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2012 at 11:27pm
You must also not have a functioning float switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottsims1 Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2012 at 11:37pm
How do I tell?
jdmoore59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdmoore59 Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 12:13am
You might want to also check if your output hose is clogged. A friends pump was behaving the exact same way. It turns out someone had shoved something into the thru-hull fitting. We used an air compressor to blow it out but you could also use water pressure if you can get a good seal on the hose.   Disconnect hose at bilge pump and blow it out.
2001 Super Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 1:00am
How do I tell?
I'd guess its either not working or not equipped since by design when the float raises with the water level, it automaticially starts the pump (even if boat is unattended) , which it is obviously not doing. Some pumps have an internal float switch, but I think most use an separate external float switch. If you're not familiar, look up bilge pumps/switches on Overtons.com or similar site.
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 12:05pm
I don't know what pump is installed on yours, but if you have the Rule pump like on our 99, it is controlled by a computer chip which from my best guess senses current draw from the pump and determines whether or not there is any water present. If you have one of these, there will be no float switch. They "look" for water I think every 2-3 minutes by switching on for a few seconds, if it senses no water pumping, it shuts back off. That may be why you're turns on for a few seconds then shuts off.
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottsims1 Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 12:17pm
Thanks for the advice. I am going to try taking the hose off and checking for any blockage. I wll let you know what happens.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2012 at 7:36pm
It's a little early for dobblers...wasps?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdmoore59 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2012 at 1:16am
In my friends case it look like china berries had been stuck into the through hull. 15 or 20 of them. They shot out like a machine gun right into my friends chest.
2001 Super Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottsims1 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2012 at 1:50am
Actually the wasps in NC love my boat. My issue is I am in the water with no easy trailer out and don't have power or a hose at the dock. My plan is to unhook the hose and blow for a check....
