Dripless Shaft Seal Comments Please |
Author | ||
74Wind
Posted: June-14-2012 at 7:20pm |
Thanks. No idea if mine has double or single taper, it's a 74 with presumably the original shaft. Any idea? Installation/alignment is critical to the process then. Can I presume by your "misaligned will fail rapidly" comment you mean it would add a whole new dimension to a wet bilge, or are we talking some mechanical failure? |
1974 Southwind 18
1975 Century Mark II |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2068 |
I sell and service the OJ seal product and have had great success installing on both double taper and single taper shafts. I dont use the tool that is supplied and utilize tape on the shaft end being installed upon and lots of grease. Have not ruined one yet but keep in mind again we do this for a living and have "all" the tools required. Personally We run the OJ Seal on our go fast stuff as well as our ski boats, when we do the 25 hour check on the new 200 I will install a new dripless OJ seal. Down side to the seal is that it does not tolerate mis-alignment well at all and will fail rapidly if a overly mis-aligned situation exist. |
M3Fan
Exactly! Awesome product other than the near-impossible installation on single taper shaft. |
BuffaloBFN
I'm very happy with my new PSS seal. It didn't come with the T or tubing though. I installed it from the prop end, but the engine was out. It was definately a timing thing...the engine was out and I had a new shaft that had the coupler trued to the shaft on a lathe. I haven't tried removing a coupler yet and don't want to.
74Wind
So you're saying you that other than tearing a seal the first time you were very pleased with the OJ for 4 years, and if you hadn't done the cutlass bearing this year you'd have continued to be happy with it, correct? Is there a reported lifespan? Not sure what I'll do, just doing some research, thanks |
1974 Southwind 18
M3Fan
I can speak for the OJ seal, which is the only one I'd buy mainly because it's fairly inexpensive. I had one for 4 summers and really liked it. There is something to be said for having at least 1 thing in the boat that you just plain don't have to worry about.
Of course, I still had a wet bilge- water from skiers (after all, we're talking about a WATERSKI boat here and if it's moving, there is somebody behind it who is covered in water) as well as water from the rudder or whatever else. YMMV. Installing a very blunt single-taper driveshaft backward through a very delicate, backward facing double-lip seal is a VERY iffy procedure (HW and CQ- I teed that one up nicely). I tore the first seal I had on installation, then got a replacement which I amazingly installed without tearing. When I did my cutlass bearings this spring, 4 years later, I tore the seal again on re-installation. Each installation attempt was done with the single-taper install tool from OJ. The tolerances are just way too tight and the tool ends up evaporating between the shaft and the inner surface of the seal housing. This time I said to hell with it and put the entire old stuffing box on. Works just fine and I'm happy with it. I'm sure it's easier with a double taper shaft OR with the engine pulled. |
74Wind
Gotta love another old-school guy who calls an unseen mechanical gadget in the bilge of an almost 40-year old boat "Bling" Tim Morfoot said he'd go check out the Southwind with me, hopefully sometime soon. Dripless would depend on what might need to be done. Century: Had been told to repack could have to remove shaft in which case dripless may certainly be worth further investigation. I'm with you on wet bilge the norm, but after seeing a hundred stringer repair threads it can make a guy paranoid....... Actually I think I'm good stringer-wise. Look for a new post "Interior Replacement analysis" and tell me what you think Thanks |
1974 Southwind 18
Jeff,
My opinion is the seal isn't really worth the effort. The exception is if you are doing major drive line R&R when you're removing it all anyway. I've been around enough old boats for so many years that a wet bilge is the norm. I suggest don't go for the "bling" unless needed. The stuffing box and now with the Gortext works big time!!! |
74Wind
Considering Dripless Shaft Seal and have read a few threads but request comments, pros, cons, advice:
Boat 1: 74 Southwind 18. Normal drip rate but may need to do dampener plate/etc (t.b.d.) so might consider dripless refit at same time. A dry bilge is a happy bilge....expecially in a 38 year old Correct Craft. Boat 2: 75 Century Mark II. Steady flow. Packing nut adjusted 2 years ago, recent attempt unsuccessful won't budge, maybe no more adjustment left and needs repacked(?) Directly under tranny (V-Drive) so must do by feel with really poor visibility in mirror, compounded by rising water. Bilge solid, nice, & clean (original owner) but never never ever wanna mess with it again, what a pain in the #@$&*.... Opinions please Thanks |
1974 Southwind 18
