Engine type from boat number?? |
GrumpyGeoff
Newbie Joined: July-16-2012 Location: Uk Status: Offline Points: 27 |
Posted: July-20-2012 at 8:07pm |
Hi guys,
We've dropped 2 clangers recently, 1 lost the tag off the engine with the model number and firing order details, and also taken all ignition leads off at the same time The boat number is CT C09782M80BSNK Its a ski nautique 1980 with the Ford PCM 351w 5.8l V8 having real problems getting the right firing order Neither 1-3-7-2-6-5-4-8 or 1-8-4-5-6-2-7-3 seem to be firing properly Can anyone help?? thanks a lot |
....Don't have children, unless you plan to win the lottery anytime soon!!
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
use the search feature and you should be able to find more info than you can shake a stick at.
This is the life
Geoff,
the hull ID will tell you nothing about the engine. It would have been the engine tag that tells all. Off hand, I feel the 18456273 in correct for a reverse rotation 351. You didn't by chance put the wrong rotation starter on it? |
NEDLUTZ
Groupie Joined: November-26-2007 Location: Seekonk Ma. Status: Offline Points: 69 |
