RWP rebuilt |
kapla
Posted: July-23-2012 at 1:08am |
Wht started almost a year ago as a little dripping, has become lately a stream of water leak.
It leak from the front shaft. Yesterday I went out and upon return I removed the pump to fix it up. pull it apart removed the snap ring and then started to pull the rubber seal, then the mechanic seal top broke in parts, then remove the mechanic seal and inspected it and seems to be fine, no visible holes in the rubber. Thats as far as i could go. How i'm supposed to pull the shaft out of the body? which tool is adviced to do the job without breaking the bank and the pump body? Bearing seems to be ok as the shaft turn freely and without any play or wooble... |
<a href="">1992 ski nautique
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2636 |
I would change the bearing, if it got wet. Was there a spring in there? Have you ordered a new seal kit?
Tim D
kapla
The spring has some rust but still there.
I will look for seal replacement locally or order one online. |
kapla
I ordered the parts, they will be here by sunday hopefully.
will update by then... |
kapla
got my parts yesterday, now going to the shop to work on the pump.
I´ve already cleaned the seat surface. The new seal need to be press fitted into the pump body. Any trick for that? other tips I might need? |
SNobsessed
Push as close to the metal can O.D. as you can to avoid distorting it.
kapla
done! used a pipe with the same diameter as the seal cup and tapped it. Will post some pictures later.
Its now ready for install and test. |
Bri892001
So, were you able to do it without a press? Was it tough to get the old one out?
kapla
no press just a hammer and slowly tapped it in..
The cup doesn't really take that much pressure. If you have a vise that opens up enough, it will work too.
kapla
new seal, little diferent from the one I removed. Also noticed the old set up had no thrust washer
old seal new parts ready to go in Pipe with same OD as the seal metal cap, ready in the press to recieve some hammer wacks! bam finished! Brian The old metal cap went off with a screwdriver, pretty much useless now... |
Bri892001
"Ready to receive some hammer whacks" That's a description I'd apply to some co-workers
kapla
finally got to install and test the pump. No leaks, temps are normal.
First succesful RWP rebuilt for me! |
Bri892001
