Ignition |
Author | ||
Yellowbird
Groupie Joined: November-04-2011 Status: Offline Points: 64 |
Posted: September-19-2012 at 9:13pm |
I have a Wildcat with a 318 electronic ignition. The engine runs strong but occasionally stops and will start after several minutes.
It's not a fuel problem, it seems to be an electrical issue. Anybody have an idea what is going on? Thanks |
Ed
Senior Member Joined: September-15-2010 Location: Corona, CA Status: Offline Points: 130 |
Sounds like the coil is getting hot. You could wait till it does it again, and see if the coil is too hot to touch, or just replace it.
Ed
Sorry, not only check the temp of the coil, but check for spark as well.
Yellowbird
I replaced the coil with no luck, has the same symptoms. Also I checked the spark after it stalled and there was no spark then after 15 minutes it fired right up.
TX Foilhead
Resistor? Does it have one, does it need one? Was the coil hot this time? Is the coil oil filled and laying on its side? Still sounds like a coil issue with no spark, but I'm not familiar with the Chrysler motors.
Yellowbird
Not sure about the resistor, I will run it tomorrow and check the coil temp.
What your saying is if the resistor is bad this will cause the coil to heat up? Ed, I apreciate your help. Thanks, Steve Todisco |
Ed
No problem Steve. Also, did you replace the cap and rotor? Just a thought.
Yellowbird
Not yet but will do it. I am also going to check the celenoid. During my researching of this problem, a failing celenoid was mentioned as a possible cause for the ignition to cut off.
Ed
Another thought Steve, Don asked about your ballast resistor. If you do have one still, make sure that it is bypassed.
I feel you are off in the wrong direction if you are referring to the starter relay (solenoid). It's only activated during engine cranking. When you checked for spark, did you check at the coil or just one of the plug wires? Checking at the coil would isolate it being the problem. |
Yellowbird
Thanks(1)
Checked the coil, no spark.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
Before you replaced the coil, exact same problem with the old coil? Sounds to me like an intermittant problem in the ignition module. |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5313 |
I second that! |
Yellowbird
Just ordered a new ignition module. Thanks guys, hope this does it.
TX Foilhead
Be sure and check what coil the ignition module wants and if it needs a resistor or not. This is one of those areas where you get away from the original and it can get confusing and cost you a lot of parts and lost time trying to fix a simple issue. I remember going through these sort of things with the external voltage regulator and the electronic ignition on my first inboard, it was a real PITA going to the lake and wondering what was going to go wrong. Good news is once you get through the learning experience you know a lot more about your boat and it should be free from those problems for quite a while.
Yellowbird
Is it normal for the coil to be extremely hot after running the engine for 20 minutes? , like 142degrees? Have not replaced the the ignition module yet.
NG, I don't see any mention of you checking the voltage to the coil. Several suggestions have been made to find out if the ballast resistor is used for you EI conversion. Do check on that. To me, that coil is running too hot. What did you replace it with? No, a bad ballast resistor will not overheat the coil. The typical failure of the resistor is a open circuit so you would get no power through it. |
Yellowbird
Replaced it with an automotive coil
Same as a marine - you are not answering the question!!!! |
Yellowbird
Not sure where to look for the ballast resistor
Steve while all engines are different most electrical items
are relatively in the same areas. Here is a picture of mine, the resistor is that white thing on the left side of the engine, middle of picture held on by a aluminium bracket. |
63 Skier
Kind of white porcelain rectangle with a thick coil of wire running through it, usually visible from the side.
Yellowbird
I see it. Will look for it tomorrow. Nice looking engine Gary, what is it?
That Steve is my 302 Holman Moody Ford that started life as a 289 but somewhere along the line has had the block replaced.
Yellowbird
Gary, I am a bit confused with this resistor stuff.
Does a coil with an internal resistor need a ballast resistor? If the coil does not have an internal resistor, is a ballast resistor nessesary? And what is the difference between the two? |
[QUOTE=Yellowbird] Gary, I am a bit confused with this resistor stuff.
Does a coil with an internal resistor need a ballast resistor? No it would not If the coil does not have an internal resistor, is a ballast resistor nessesary? Yes And what is the difference between the two? Coils can't run at the full 12 volts so the voltage needs to be reduced somehow. You cannot go wrong with one like this one it's epoxy filled so it can be mounted in any position and you need this resistor to go with it. You can tell if it is an oil filled coil by shaking it and they are not to be mounted on their side |
Yellowbird
Thanks for your help Gary.
Yellowbird
Is there a wiring diagram anywhere for connecting an external resistor to a coil???
Check here second page
