Engine & Prop Rotation |
bmrichards
Newbie Joined: October-14-2012 Location: Kelowna, Canada Status: Offline Points: 3 |
Posted: October-15-2012 at 8:22pm |
Hello gentleman, this is my 1st post on this forum and i'm sure this has been discussed many times, I recently purchased a 1994 SN 196 with the 5.8L Pro Boss EFI TBI engine. I know that that boat pulls in to left in reverse but is it the engine rotation that is doing that or the drive?
I guy at work is telling me that the engine runs in the opposite direction but it looks normal to me. Barry |
snipe
Senior Member Joined: July-13-2009 Location: United States Status: Offline Points: 157 |
Look at the prop from the rear. If it turns clockwise it is a "right hand rotation". Counter-clockwise is "left hand rotation". I suspect that yours will be right hand.
You have a RH prop for sure. All Ski Nautiques do. Prior to 1989, CC accomplished this by using reverse rotation motors. In 1989, CC started using PCM's 1.23:1 transmission, which reverses the direction of engine rotation. This allowed them to start using conventional (standard, ie LH) rotation engines, while keeping their trademark RH prop.
By and large, most direct drive CC's made 1989 and later use the 1.23:1 transmission, and have LH engines. However, CC made some "standard" models in 1993-1994 that used RH rotation engines mated to 1:1 PCM transmissions (which do not reverse the engine rotation). So, based on the information youve given us, we cant tell which you have. If you can get us the information on the transmission tag, or the information off the engine tag (located on the intake manifold) that would be pretty definitive. |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
Provided You have a reduction (1.23:1) transmission and not a 1:1 your engine is standard rotation (left hand) however your transmission will turn the opposite direction (Right hand)as will your propeller, hence why your boat backs to the left. Now had you have one of the "Scrappy" SN it had a 1:1 transmission and a right hand rotation motor all turning right,,,still backing to the left.
Hope this helps with your question |
bmrichards
Thanks guy's I will check my transmission tag & post. It's starting to get colder up here so its time to put her to sleep.
Barry |
