  New Posts New Posts RSS Feed - Winterized?
Winterized?
mike32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Topic: Winterized?
    Posted: November-04-2012 at 9:09pm
2002 San with Chevy 5.7. I drained out all hoses, removed two plugs from the block, two plugs from manifold, a hose that went into the lower section of the block starboard side, plug from trans cooler. Then I removed the temp sensor from the manifold and poured in antifreeze until it came out of the block drain holes. Did I forget anything, are there really only two drain holes in the block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2012 at 9:18pm
Yes, there are only two drain points on the actual block. It sounds like you got it!! However, how about the trans cooler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike32 Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2012 at 11:12pm
I removed the plug from the trans cooler and the two plugs from the vdrive.
