  New Posts New Posts RSS Feed - Sh/%$tty night
Sh/%$tty night
connorssons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Topic: Sh/%$tty night
    Posted: November-24-2012 at 12:42pm
Was out working on call yesterday, recieved call that the fire dept was at my house got home to see that my woodshead was burned up and my central boiler had caught fire on the outside, due to wiring issues. total loss of burner its gonna be cold for a while!
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 2:31pm
Ouch...
Hope you get things back in order soon...
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 8:08pm
gR@HaM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 8:35pm
Bad luck, or maybe not it sounds like things could have been a lot worse!
'82 Ski Tique
skicat2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 9:00pm
Things happen for a reason. Why you where on call. Just think you could have been working in the woodshead, instead of working. Somebody is looking out for you. Good luck and hope everything gets back to normal. Be Well!
1985 CC 2001-SOLD
Lee Michael Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 9:17pm
Jeff,
It's always sad to hear about bad news. Just keep going and replace the boiler. This, however gives you the opportunity to go with something with greater efficiency. I can not say enough for the Triangle Tube boiler I installed in my shop I build up north. My gas bills are coming in at an average of $50 per month through the heating season keeping the temp set at 50. When I'm up there for Christmas and New Years, I'll kick it up to 68 for the roughly 10 days. It's also heating my domestic hot water.
BTW, I thinks you need a better electrician!! It sounds like a hack job to me! You didn't wire it yourself did you?
juniorwoody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 9:19pm
That's a mess. Best wishes getting everything back in order.
The value of money spent on new adventure far exceeds the value of money saved for the future
DrStevens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrStevens Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 9:47pm
Jeff, so sorry to hear about this, at least it is not your main house, or the new barn. The property seems to be jinxed with fire incidences, glad no one was injured.   SH
peter1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter1234 Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 10:34pm
why assume its a hack job? I have seen more taco 007 circs short out inside their covers through the yrs. also ice cubes on argo and taco controls. those wood fired systems have all that stuff plus other misc controls and wires all packed into a small covered space its no wonder there arent more fires . sorry to hear about it Jeff .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 11:19pm
If the NEC is not followed and there isn't any MOP. then yes it's a "hack job".
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: November-24-2012 at 11:47pm
sheeeze enough already.....cut some slack pete buddy what's up...you needs to chill a bit, just sayin
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 12:19am
+1 No kidding!! Guy's house practicaly burns down and he has no heat during the first really nasty cold spell this year. I am guessing the last thing he is interested in is criticisms and lectures. Sorry about what happened Jeff, hope you are back up and running quickly.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 12:37am
Sad to hear Jeff, I hope you get back up and running soon. On the bright side at least it did not get the boat barn.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 11:38am
Jeff,
Larry and Jack,
Yes, the word "hack" may have been harsh but it was intentional. This is Jeff's second fire. Most fires are ether caused by bad electrics or bad wood burning installs although I do not believe Jeff's first fire was ever confirmed to be from electrics. I have seen way too many bad electrics done by so called pros and or homeowners. 18 ga. lamp cord (SPT-1) running through a wall with a 20 amp load on it is a great example. In rural areas where there aren't electrical inspections seem to be the worst. The NEC has been written from many years of experience and is meant to protect. It's sad that the "hackers" don't even know about it.
So, the bottom line is my harsh statement with using the word "hack", was a concern but more so a warning. No, a fire is always bad and I sure do not want it to happen to anyone.
Peter,
Don't get me going about what I have seen the HVAC trade do out there!!! It's bad enough what the HVAC OEM's do with their electrics!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote connorssons Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 12:25pm
Hack job! u got that right, first fire was due to sh5tty chimney install on property we purchased from bank that thay repoed. 2nd fire was do to rodents making little houses under boiler little guys need heat to! I have thick skin so all coments are welcome, thanks for all the nice coments guys. so far the insurance co has been good, will keep ya posted!
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 1:47pm
Sorry about your loss Jeff. Glad it wasnt any worse. Good luck on the rebuild!
83Ski
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 2:48pm
That should get rid of the rodents
This is the life
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 2:52pm
WOW----------- Sorry to hear this about a fire and no heat-- As long as everone is ok- Then ,all will be fine, in the end...BOL , going forward..
john b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2012 at 3:42pm
Sorry to hear that. Good luck with the repairs!
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late!
ononewheel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ononewheel Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 4:43am
Yikes.    Glad nobody was injured.    I so feel your pain right now.
If we let the professionals do everything it takes all the fun out of youtube
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 9:39am
Glad no Correct Crafts or CorrectCraftFans... or anyone else was hurt!
Hope you can get up and running with your heat soon.
turningpoint84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turningpoint84 Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 4:58pm
Pete I just wired my 240V oven range with 14-3 since it need 4 wires. I'm good right?
Proud 1968 mustang owner and now
1970 Mustang
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 6:40pm
I hope you are joking...    unless the pigtail is about 3" long, or your oven only pulls 15 Amps, you'd better rethink that 14 guage wire....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 9:51pm
Peter,
You certainly must be joking. A range/oven will pull more than the 15 amp load that 14 ga. can handle even considering a short run. GET A licensed ELECTRICIAN. What is the breaker size you hooked it up to????? Do you what to make a claim to your insurance company?
Why 4 wires??? You have two "hots" and a ground! You are certainly in a are where you should not be.
You certainly must be "pulling my leg" since you can not be that stupid??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 10:59pm
Peter,
I was joking on the 3" pigtail, but not about 15 amps...   TP84, are you using an easy bake with a hot plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2012 at 11:12pm
Easy Bake oven!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2012 at 10:38am
Pete I had the same problem with my stove install used 14 wire also(thats what I had lying around) kept popping the breaker. Finally had to put a 100 amp breaker in now it doesn't pop anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2012 at 11:01am
Hey Jeff, sorry to hear! it sucks dealing with/cleaning up/rebuilding after a fire. Good luck with everything!
Are you wood-only for a fuel? Does the boiler heat both the house and the barn? Curiuos what direction you will go for a replacemnent. That panel looks HUGE for a home installation.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2012 at 9:40pm
4 wire is now std for range wiring. Extra ground.   I always oversize 1 gage, cheap insurance.
