Water Hose from SKIDIM |
HatterBee
Gold Member Joined: April-29-2011 Location: Burgaw NC Status: Offline Points: 505 |
Posted: April-01-2013 at 3:10pm |
Has anyone ever used this water hose from SKIDIM. It looks a little rigid. I need to get some new hose for the '77 rebuild. Any advise would be helpful. Thanks Allen
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Allen I used it this winter to re-plumb my boat and it worked fine.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21120 |
Allen, there are only a few different types of cooling hose out there... that green stripe stuff that SkiDIM sells is pretty common- Ive seen it in many CC's. I actually went to Jamestown for my last few runs of hose though- simply because I preferred the blue stripe over the green. Both types work just fine. I would imagine you'd need 1" rather than 1-1/4" so just make sure you know what you need before pulling the trigger.
Trident Hose at Jamestown Distributors |
HatterBee
Thanks guys,
Tim everything on this boat was 1 1/4 so I will go back with that. thanks again. |
Foot_Fungus
Gold Member Joined: February-27-2012 Location: Chapin, SC Status: Offline Points: 501 |
I have it on my boat. its some stiff stuff for sure.
'94SN Restoration underway...
Wire reinforced hose really isn't needed on the pressure side of the cooling system.
Non wire from Jamestown |
snipe
Senior Member Joined: July-13-2009 Location: United States Status: Offline Points: 157 |
I use the wire reinforced from the raw water intake to the pump. (Suction side) and any where there is pressure after that you can get by with regular non wire reinforced hose. That's just to insure that the hose doesn't collapse while drawing water in.
