94 sport nautique center walk thru windshield door |
kylem428
Senior Member Joined: May-31-2005 Location: United States Status: Offline Points: 261 |
Posted: April-15-2013 at 9:45pm |
So does anyone know where I might be able to find replacement glass for my walk thru windshield door? I was replacing the latches and the screw was too long . The windshield is a Taylormade, and the frame appears to have a slight bend. My glass guy said a flat piece most likely wont work, but he could put a piece of polycrylic (sp?) in there. What would you do? I am guessing this may end up being a costly mistake. I called my local dealer and left messages at nautique parts, n3 boat works, and Taylormade.
Thanks, Kyle |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
$5 says its a flat piece of glass that simply bends slightly once installed.
kylem428
Yeh Tim, I think that's a $30 risk I'm willing to take just to find out. If it doesnt work and If I have to go acrylic, think anyone but me would notice?
Kyle |
You can see the difference with acrylic and it scratches more easily... So stick with glass if you can. All of the flat single pane windshields from the early 80's and early 90's were flat glass installed with a slight bend. I'd be amazed if yours wasn't flat as well.
ononewheel
Gold Member Joined: June-21-2011 Location: B Status: Offline Points: 776 |
On my 94 the glass is all flat, every single piece.
Last summer I tinted them. When I took them apart I thought reassembly would be easy because of the bend they had. Nope, they were all flat. Still easy to reassemble, except for peeling the newly installed trim with the tight fit because of the bend. I should have painted it while it was apart. |
If we let the professionals do everything it takes all the fun out of youtube
Kyle, I'd find a new glass shop if he thinks the glass won't bend. |
kylem428
I'm taking the chance that the $30 flat piece of 1/8" tempered glass will fit and adjust to the slight contour of the frame. I had him order the size I need, and if need be, I'll put it in. Can't be that hard. I don't even want to call taylormade to see how much an OEM replacement would be.
Kyle |
