  New Posts New Posts RSS Feed - ??HIGH IDLE??
??HIGH IDLE??
key View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote key Quote  Post ReplyReply Direct Link To This Post Topic: ??HIGH IDLE??
    Posted: May-13-2013 at 5:57pm
Boat is idling high in neutral. Hits hard when you go into gear or reverse do to it idling high. Im not much of a mechanic but have tools and common since. Can someone help me in the right direction? Thanks!!
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2013 at 6:11pm
I get it, this is a guessing game, i'm first, lol
Really need to provide more info, motor and specs, boat yr, etc.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2013 at 10:05pm
Assuming 351 with carb --
Have you tried to adjust the idle?
Most of the time it is a vacuum leak. Try tightening the carb hex nuts. Another trick is to spray carb cleaner at all possible leak paths - the engine will slow down if you find a leak with that.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2013 at 7:55pm
I had the same issue when I first bought my '76. Loading on trailer was a pain. Replaced the carb at a CC dealer. That corrected the high idle but when the boat went into gear it'd engage too late and too fast. It was then did I realize the gear shift cable on the transmission was out of adjustment also. Adjusted the cable in the middle of the lake and its been as smooth as a Cadillac ever since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2013 at 9:14pm
Did the dealer actually replace the carb? Didn't they even bother to check and test the cable adjustments? Maybe that's why some dealership changes have been made in your area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2013 at 11:58pm
Yeah they replaced the carb but they don't water test the boats. I doubt they even put it in gear. But then I again I never suspected shift cable issues bc the old carb was so whack. I'm was glad it was a minor adjustment bc it was rather annoying and dangerous.
The dealerships here sure took a tank. When CC changed hands it was the end of an era. I will say Orlando Nautiques have been much better to us than Southeast Marine was but nothing compared to when the original Southeast CC was around.
