  New Posts New Posts RSS Feed - Fuel Filter Question
Fatboy206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatboy206 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Filter Question
    Posted: May-26-2013 at 3:12am
I have a 2008 SN206 with a 5.7 L PCM motor.
I replaced the in-line fuel filter, the cannister between the fuel tank and the FCC unit.
I then struggled to start the motor again, motor spluttered, died, did this half a dozen times or so before I got the motor running again which I was able to do by upping the RPM's a tad and after a few minutes motor was running smoothly again.
Any advice or suggestions on the correct procedure to replace the fuel cannister would be appreciated please. Thank you.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2013 at 10:33am
Can you prime the system somehow? Sounds like it was sucking air for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fatboy206 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2013 at 11:04am
I'll try disconnecting the fuel line after the FCC unit and bleed the line. There are two lines, I guess one must be the fuel return line, the other the supply line. Both have a retaining clip of sorts but after taking the clips off I was still unable to get the fuel hoses off the fuel rail. Thought I'd cycle the ignition a few times to bleed the system of any air. Can't figure out how to get the fuel hoses off the fuel rail once the clips are off though?
