Starter relay |
gR@HaM
Platinum Member Joined: May-01-2012 Location: UK Status: Offline Points: 1265 |
Posted: June-03-2013 at 9:34am |
Due this look right, not sure whether its classd as the relay.. but the electrical 'cannister' on the RHS:
Im yet to find pictures of anything similar on the web so am wondering whether this is non-original (wouldnt be surprised with this boat!!) Also, Im in the process of wiring everthing back together.. as I managed to lose all the photos I took whilst dismantling I need to know what the connector with the white masking tape tab in the photo should be wired to?? As always - any help muchos appreciated.. |
'82 Ski Tique
SNobsessed
I believe that terminal goes to the starter.
TX Foilhead
battery on one side starter on the other. Looks scary close to the housing holding the 50amp breaker, you might want to move that over some.
gR@HaM
Thanks, should have worked that one out!!
Thatll the big chunky black wire that connects to the starter then. Yeah I was trying to work out why the breaker and relay don't seem to fit correctly to the mounting plate, even more so when I try to line the fuse up with the plastic cover |
'82 Ski Tique
As well as the one terminal on the ballast resistor. |
TX Foilhead
Not to long after I saw this I was wandering around in West Marine. They had plenty of relays like that, so I would guess it will work.
My balast resistor has a 2 reds on one side and a purple and black on the other. I used the hand drawn ProTec replacement pic for where they go. ( sorry too much beer and I'm too lazy to look through the harness). |
Graham,
Play around with the bracket to see if you have the mounting positions for the breaker and relay correct. I don't feel they are in the correct place. |
gR@HaM
yep, will do. tbh I gave up the other night and just disconnected the relay from the bracket for the purpose of starting the engine.
Fingers crossed Ill get it fired up this week.. |
'82 Ski Tique
