  New Posts New Posts RSS Feed - trans oil cooler
trans oil cooler
gR@HaM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Topic: trans oil cooler
    Posted: June-03-2013 at 6:57pm
Pretty sure it isn't but will never know unless I ask!
Is the oil cooler directional?
Also, does anyone have a picture of what the bracket looks like? I'm looking to make something but not sure what to bolt it to on the engine, keeping in mind I have a strainer on order..
'82 Ski Tique
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 7:23pm
Mine is same as the coil bracket and I bolted it to the outside bolt hole on the back of the head.   Not sure thats right, but it works. Mine came with a twisted coil bracket and didn't have enough hose to reach a suitable spot, I just got a new straight bracket and added enough hose to get it to the closest place.
cphase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cphase Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 7:43pm
Thanks,
Jeff
82 SN
Arch Linux
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 8:36pm
The oil flow direction needs to be opposite to the water flow direction.
I hope this makes sense
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2013 at 8:43pm
Grahan,
Chris is correct. The direction of flow maintains the max delta T keeping the efficiency of heat transfer high. So, you will want to feel the oil cooler from the starboard side per your picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2013 at 10:28am
Thanks, yep makes perfect sense.. other than the fact that I dont understand direction of flow with the trans oil hoses!!
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2013 at 10:29am
Grahan,
Noted.. so I connect the side of the oil coller without the drain plug to the hull. Simples
'82 Ski Tique
