gas sending unit |
Author | |||
Dellavalle
Newbie Joined: May-26-2012 Location: Lake Placid Status: Offline Points: 16 |
Posted: June-17-2013 at 2:41pm |
1982 /2001 model / gauge works when I jump out the contacts, power to sender, no gauge movement unless I place probe tester power of sending unit and ground, then gauge goes to 1/4 plus reading.
Tank has a good ground, sending unit now has positive and negative( ground ) feeds, no better with the gauge. Do I have to remove the tank to remove the sending unit ? And what type of new sending unit ? Thanks all ! |
Bri892001
I don't think you'll have to remove the tank. You'll definitely have to get the seat out of the way.
Here is a sending unit: http://www.n3boatworks.com/catalog_product_detail.asp?cat=5045-91698&product=868468 N3BoatWorks offers a 10% discount to CorrectCraftFans. |
Dellavalle, You should NOT have a positive connection to the tank sender. The sender is the ground source for the gauge. Positive to the gauge, sender wire from it to the tank. If the sender wire is removed and grounded removing all the resistance of the sender, the gauge should peg at max. What are the "contacts" you are jumping? |
OldSchoolBlue84
Replaced mine a couple of weeks ago and was easy, no removal of the tank. Just have a small socket wrench to reach the back screw. Bought mine from nautique skins, fit like a glove, very close to original.
When the needle gets pegged to full when you take the positive cable (red) and make contact with the ground (black) while the ignition is at the on position, then you have a bad sender. Good luck... |
Kostas
1984 Ski Nautique 2001 |
I don't think you should be connecting a positive to a negative!! |
Dellavalle
Sending unit, pink wire ( red ) to screw down post,comes from the gauge. Tank is grounded. with power on, at the gauge, should read full if pink wire is grounded directly to tank, not the post, indicating a bad sender, am I correct ?
Bri892001
That sounds right. But, that Pink, not Red, is a very important distinction. |
OldSchoolBlue84
Correct, that is what I have been told.
Correction, reviewed my pic and yes it was a pink wire, not red. Sorry for the confusion. |
Kostas
gun-driver
Could be a saturated float happened to my '85 replaced cork with a new foam float works like a charm.
Pull the sending unit out turn on the key, raise and lower the float arm look for reading on the gauge. |
gR@HaM
Platinum Member Joined: May-01-2012 Location: UK Status: Offline Points: 1265 |
Dellavalle, please take a photo of how you are wiring it - not only will it help others understand you question but will also aid me as cant get mine working since removing the tank!! |
'82 Ski Tique
turningpoint84
Platinum Member Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
If i were ordering a sending unit I'm getting one of these.......
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=26697&title=fuel-sender-replacement |
Proud 1968 mustang owner and now
1970 Mustang |
Graham, Is the tank grounded to the engine?? |
baitkiller
Pete, that is a different wire for a different reason. Dont confuse him. |
Bri892001
Well, not exactly different. Temp senders and oil pressure senders work by being a variable resister to ground (the engine block). Fuel senders also work by being variable resisters to ground, again the engine block. But, since the tank is not the engine block, it first needs to be grounded to the engine block. Well, if not the tank itself, then at least the outer ring part of the sender. There does seem to be some confusion around grounding the tank for reasons of spark control while fueling, and grounding the tank (or sender ring/tab) for reasons of making the sender work. That's why there is sometimes talk of being three wires back there. One is the sender wire. One is the ground that goes from tank to engine block and one is for the stern light ground. |
