  New Posts New Posts RSS Feed - Wiring Clarification
Plan B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plan B Quote  Post ReplyReply Direct Link To This Post Topic: Wiring Clarification
    Posted: July-23-2013 at 10:53pm
Hello all,
I'm a bit confused and just want to make sure I'm wired correctly..
I have been referring to this diagram:
http://www.correctcraftfan.com/forum/uploads/824/enginewiring84.jpg
My confusion is at the Ballast Resistor section.
I have a 351 with an electronic ignition (flamethrower II) and a voltage regulator in place of the ballast resistor shown in the diagram. I currently have the red, green, and, purple wire going to their respective contacts on the voltage regulator.
From this diagram, am I supposed to remove the voltage regulator and just splice the red green and purple together or, is what I have correct?
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2013 at 11:13pm
Ballast resistor if for the ignition, the voltage regulator is for the alternator. 2 different systems so you shouldn't change anything on the voltage regulator because you changed something on the ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plan B Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2013 at 11:21pm
Ok, so what I have is correct thanks! I was just confused with the diagram having the red green and purple tied together.
