  New Posts New Posts RSS Feed - Control Cable Question
sam57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sam57 Quote  Post ReplyReply Direct Link To This Post Topic: Control Cable Question
    Posted: July-28-2013 at 2:46pm
My recently purchased 1977 Southwind 20 with PCM 351 has cable and Morse control issues. Both cables come from the front of the engine instead of the throttle cable coming from the back and lever has to move way too far for the transmission to engage. I need the correct length of each cable and a diagram of how they attach to the Morse. Also, Is Nautique Parts a good place to deal with?
Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2013 at 5:05pm
Does not matter where the cables come from just as long as it works. The travel will be the same no matter how long the cable is. You'll have to look at the control to fix your problems,check it and see where the cables actually attach to the levers,furthest out holes on the control will make the travel longer etc
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2013 at 9:52pm
Sam, take some pictures so we can see what you're dealing with.
Getting the cables to work together properly can be a bit tricky. My 78 wasn't quite right until Zach and I messed with it at the GL reunion. Be patient, post some pics and I'm sure we can help you figure it out
