1999 Ski Nautique won't start |
jaw
Newbie Joined: July-29-2013 Location: Maryland Status: Offline Points: 3 |
Posted: July-29-2013 at 5:36pm |
1999 Ski Nautique won't start. Just put it in the water. Started fine, replaced impeller and belts. Started fine, turned it off, now it won't start, getting spark, getting gas. Any ideas?
Dreaming
fuel, air, fire.... if it's getting gas, and getting spark, then I would suggest that your fuel supply is weak (points to the FCC?) or that your spark is incorrect. Do a search for the fuel control cell hose repair... that seems to be a common problem. Knowing what engine you have would help too... welcome to the forum!
jaw
The engine is a GT40. engine 260 hours.
phatsat67
Take the FCC off and see how much fuel is in it. Should be full nearly to the top. If it isn't you have a low pressure fuel supply problem.
It really helps to have a fuel pressure tester kit on the fuel injected boats. Takes away a lot of guess work. |
Hollywood
Disconnect your safety lanyard, reconnect and try again.
phatsat67
oooooo HW coming around the back side!!
slob02
Newbie Joined: May-20-2009 Location: United States Status: Offline Points: 5 |
Do you hear the fuel pumps cycle when you turn the ignition on? These motors had problems with the fuel pump relays.
slob02
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
Did the safety lanyard get disconnected?
- Jeff
1999 Ski Nautique |
