  New Posts New Posts RSS Feed - Boat hesitates and stalls @ high rpms
jgold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgold Quote  Post ReplyReply Direct Link To This Post Topic: Boat hesitates and stalls @ high rpms
    Posted: August-04-2013 at 12:29am
I have a 1983 Ski Nautique 2001 with a 351 Commander engine. It ran great until a few weeks ago. I tried putting a new coil, fuel filter and fuel pump on it and it is still doing the same thing. The boat came with a prestolite ignition that I converted to an electronic ignition with a conversion kit in 2008. The boat runs great for 5 or 10 minutes. Then it spits and hesitates sometimes dying. It has been idling fine all the time. Any advice would be greatly appreciated.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2013 at 8:55am
When it acts up, I would pull the coil wire out of the dizzy & hold next to a engine ground (bolt head). You want to see a big blue spark, not a yellow one. Its a good idea to wear gloves if you don't like the feel of 10,000 volts.
This will at least get you focused on fuel vs. ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgold Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2013 at 10:31am
SNobsessed,
I will check that and get back to you. I have one question. Could the problem be in the distributor?
Thanks,
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2013 at 6:45pm
Symptoms indicate it running out of gas.
Clean out the fuel pickup, and antisyphon valve.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgold Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2013 at 11:29pm
Thank you for the advice. I took the anti-siphon valve out. It looked clean. The fuel pickup line is welded into the tank. So I blew air into it with my air compressor. The boat ran great all weekend. I am just wondering if I will pick trash up again soon?
Thanks again for the help.
