  New Posts New Posts RSS Feed - Spark Arrestor
Spark Arrestor
Georges82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Georges82 Quote  Post ReplyReply Direct Link To This Post Topic: Spark Arrestor
    Posted: August-11-2013 at 3:09pm
The previous owner of my 1982 2001 installed an edelbrock semi hi rise manifold, the engine cover would not close so he put a 2x4 under the rear of the engine cover and bolted the hinges to it.
Does anyone know if there is a shorter spark arrestor I could use to get rid of the 2x4?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2013 at 3:28pm
George,
Yes there are low profile arrestors. Some searching on site will get you the exact answer. It sounds like the PO did some hack work! Did he hard line the high pressure side of the fuel pump to the carb? If not and he ran rubber hose, it may be against USCG regs and you may be driving a potential bomb. How about some pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Georges82 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2013 at 4:11pm
Has the hard line to the carb.
Will try to figure out how to post pics. Thanks
