VDO gauges |
norrisdam
Newbie Joined: August-26-2013 Location: Ohio Status: Offline Points: 36 |
Posted: August-26-2013 at 7:07pm |
Does anyone know where to obtain VDO gauges. I have a 1986 Martinique and am looking to replace a few of the gauges.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
E-Bay had or has some clocks. Check under Correct Craft or Nautique.
norrisdam
I will check it out.
cooperlacy
Groupie Joined: September-14-2009 Location: Cutler, IN Status: Offline Points: 60 |
http://www.egauges.com/ has good pricing and selection of VDO gauges. I've bought VDO gauges from them before for automotive use. I don't know if they have a line that matches your current gauges.
Air206
Rod Velde (Velde99) has the clock ...it's a white face VDO.... Summitracing has the black-faced standard series gauges.
Here is a good link. I have bought from them before with no problem. Why don't you post the gauges you want to match,I might have some used ones.
Air206
I have a used Black-faced Airguide (like the one pictured) available if you need one.......
norrisdam
I am replacing the fuel, voltmeter and water temp gauges. They all work fine but they are 27 years old and they look it.
egauges looks good. |
JPASS
Christines has some Faria gauges. Not sure if you want to go that route, but here's the link
'92 Correctcraft Ski Nautique
backfoot100
When I did my rebuild I replaced all my gauges with VDO from egauges. They won't have OEM if that's what you're looking for. They have plenty of choices for your application. Just keep in mind that you need to verify that the gauges you buy match the impedance of the senders in your boat or they'll be inaccurate. |
Eddie |
norrisdam
Thanks for the info.
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
ah, yes I have been trying to hunt down VDO industrial gauges for some time, they stopped making them for a few years now. I think if you disassemble the gauges you buff and wax the face, idk. I only have 810 hours on my CC, have the same gauges, I cover them whenever we aren't under way. Strange tho, my uncles 87 Martinique has 1200 hours and the gauges are getting faded, but our friends 86 Martinique has over 1700 hours and they look great! Original gauges too! Dont know how... Before you get rid of the old gauges, let me know, might want to take one or two from ya, and try the buff and wax deal...
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
Air206
Check with Rod Velde... he's your VDO hook up! PM or email him.......
