  New Posts New Posts RSS Feed - '94 pcm 5.8l pro boss pro tec ignition parts
kylem428 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kylem428 Quote  Post ReplyReply Direct Link To This Post Topic: '94 pcm 5.8l pro boss pro tec ignition parts
    Posted: September-17-2013 at 11:47pm
As the subject says, I have parts from my '94 pro tec ignition that I swapped for the distributor system because it was mysteriously going in to limp mode. I have the wire harness, control module, coil packs, plug wires, and crank position sensor. The parts made the boat run well intermittently this spring. Not sure which components are functioning entirely as intended so full disclosure here. These parts would make an option for spares if someone is looking to patch up a system with a known bad part. Probably not worth much but make me an offer I can't refuse shipped from 54501.
Kyle
