  New Posts New Posts RSS Feed - Wake plate
Wake plate
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Topic: Wake plate
    Posted: March-06-2014 at 5:20pm
Has anyone installed a wake plate on an older nautique?
Been thinking about fabbing one up.
- waterdog -
78 Ski Tique
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 6:13pm
Define older
Originally posted by Air206 Air206 wrote:
I like my secret weapon....
Monster Tab plus shortened shaft and new prop (still dialing in rpm/prop) but much, much, much less bowrise!
bring the ruckus
2000 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 6:54pm
Hey Adam,
   On my 2001, a hinged plate could be bolted to the existing
holes on the middle 2 platform brackets. A long pin (like the pin that adjusts the outboard angle on our toon) would be used to adjust the angle manually. Maybe 3 positions down and 1 up/stowed.
It would have a wicker bill on it to fine tune the "hook"
It COULD be removed with NO evidence of it being there at all.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 7:39pm
My only question would be, if that hull was not designed to support the resulting load, could you be inviting unwanted structural damage?
bring the ruckus
2000 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 8:04pm
The platform would be thou bolted(are they lag bolts now?)
so the gas tank would come out on install. I'd bond/bed a 1/4
inch aluminum doubler behind the gas tank with aircraft anchor-nuts
so the tank wouldn't have to be removed again and the plate
would cover the inside and outside bolts on the center 2
platform rackets.
The wake plate would be mounted to the inboard bolts only.
I'm thinking this thou as I type - engineering it on the fly!
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 8:12pm
Im sure it could be done... the question is- what would its purpose be? What are you trying to improve (wake, handling, tracking) and for what discipline?
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 8:16pm
Mine really needs the sac(550) or 5+ folks on board to kill the 'lip'. Does a plate affect that effect?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 8:22pm
Tim,
At wake speeds (pretty much 22) kill the lip
on the wake and maybe slow down. The big boys
board at 18 ish.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 8:35pm
Andy, I need a translator :)
Wake speeds... So wakeboarding?
Kill the lip... Meaning wake size? Or shape? Bigger, smaller, vertical or rampy?
Greg, are you talking about cleaning up the washy lip on the bfn? The trend I've noticed is that a lighter boat seems to clean it up a little... But it's tough to get rid of it entirely (even at barefoot speeds).
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 9:07pm
Originally posted by IAughtNaut IAughtNaut wrote:
Define older
Tim, yes the washy lip. My uneducated experience is the reverse though. When the boat was new to me (read heavy), the wake was pretty darn nice with a driver and rider; CG limit added-it was huge. It likes the weight now....and burns less gas w/o it.
Pardon the thread jack; I don't quite understand the plate and how it works.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2014 at 9:36pm
My boat has a very nice wake at wake boarding speed (22MPH ish for a 2001) The ramp on the wake just before it gets that white wash has a curl(a bad thing) then it falls off to the white wash. So you look for that sweet spot with little to no curl by shortening/lengthening the towline.
I've made a set of brackets that boost the height of the fly high pole more than a foot.( like a Tachyon) and that helps but in search for that wake snob wake. Maybe a plate would help a little too.
The big boats G23, Epic ect. throw a perfect ramp/wake much slower 18 or so. But they aren't 30 years old ether.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2014 at 12:08am
Does HW still catch these?!!?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2014 at 10:32am
Greg, your comments seem to pertain to wake size and not shape, so Im not sure we're on the same page. Maybe a pic will help. This is our '79 at footing speed (obviously). The boat was probably in a very slight turn, resulting in a washy lip on the right, and a clean lip on the left.
I have found the washy lip to be good for absolutely nothing. Its a toe catcher at barefoot speeds, and at slower speeds (trick/wakeboarding) it doesnt provide any "pop", so the large size of the wake goes to waste, to some extent.
The shape of the BFN wake and the 2001 wake are very different, due to the different hull design (deep vee vs. flat bottom). The 2001 tends to have a very well defined wake, with hard features. The 3 pronged rooster extends back to create a wake within the wake and a well defined, steep curl. Great for tricking and wakeboarding.
Concerning wake size and shape at slower (wake/trick) speeds, more weight in the back will result in a taller, steeper (more "vertical") wake. Putting weight in the front of the boat will mellow the wake out a little- resulting in a more "rampy" wake. Finding the right balance of weight in the boat (location and amount) for the speed that youre riding is the topic of endless discussion on other sites.
A wake plate would essentially add hook the the rear of the hull. It would do the same thing as adding weight to the front of the boat, without the accompanying growth in height- ie, it will make the wake rampier (less vertical). How much depends on the size and angle of the plate. It will also likely have a TBD affect on wake shape, as changing the running surface of the boat will change the shape of the rooster and resulting wake to some degree.
Andy, it is pretty common for guys to tailor weight placement, rope length and speed to specific preferences/riding styles. There is no real "wakeboard speed" per se... its all dependent on the above variables. You see guys riding at speeds ranging from 22mph to 26mph and all sorts of line lengths, depending on the rider's preference and the boat theyre riding behind. It *sounds* like what youre trying to do is to alter the boat/wake when it might be better (and easier) to alter the line or speed. If youre fighting to get ahead of the curl where it starts to wash over, you can either speed up a bit or shorten the line.
Generally speaking, a 2001 should throw a cleaner wake at a slower speed than a larger, heavier boat. The sweet spot is also likely to occur at a shorter line length than some of the big wake boats. I remember back in the day when I was a young teenager (mid 90's), I would ride at 22-28' off at ~18mph behind our '92. These days, those numbers are about the same when I want to air it out on the tricks. Add weight, you need to speed up to get the wake clean again, and you need to lengthen the rope to find that sweet spot again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2014 at 11:42am
I'm a poor communicator. I get a little 'slosh' on top w/o the weight. It's no biggie. And the observer can adjust it easily.
Reminds me of a time I had a boat full of folks who had never been on a small boat. For a few minutes, I had everyone push on the inside of a turn so it wouldn't roll over.
They got me back later that day.
1988 BFN-sold
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2014 at 8:47pm
Altering the manufacturer's design does present personal liability if something goes wrong out on the water.
If you do add the plate, test it well under extreme conditions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 9:16am
Crap - now I have to remove my 300hp roller rocker engine(anybody have a 240hp stock engine) Also for sale is a 540 prop and a nice fly high pole with a custom bracket.
Kidding - I'm KIDDING !
The bracket will be well thought out and over engineered.
With the tune-able wicker bill, the the boat roll to the drivers side could be "tuned out" so the boat would throw an equal wake port & starboard. With only the driver pulling a boarder.
PS - are he platform brackets lag or thou bolted on a 2001?
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 10:53am
Andy, before I would put a wake plate on there have you considered adding more fat sacs? I've been boarding behind 2001's since the mid 90's using mainly mine and and buddy down the roads boats. Mine is usually under weighted with 172 lbs of lead weight on the floor where the observer would sit (to counter balance the driver wt) and a 540lb sac just in front of the stern seat. The wake is great for me but not enough for my bud whose set up is different.
He uses two cubes in the observer seat and floor weighing 80lbs a piece. A 600lb sac in front of the Stern seat and another 500lb sac on the stern seat (half full). He's got about 100lbs of lead in the bow and about another 100 lbs of lead on each side of the gas tank. The wake is monsterous (to me anyway ) and the wake literally throws you in the air. He uses two tsunami pumps to fill/empty the sacs so it only takes 20 mins or so to load her up for boarding. He is still using a federal 13x13 prop and I have tried several times to get him to upgrade to a 540 but he won't. You really gotta get on the throttle to get all that weight moving but geez louise it's huge. He's had this set up for years and I it's starting to take it's toll on his body. He has braces on both knees, both elbows and a carpel tunnel thinga-ma-bob on his forearm. He doesn't go boarding 3 times a week anymore as fuel has gotten higher and he bought a couple standup jetskis.
We all know that the wake is key in throwing some of these tricks that the pros are doing but technic is bottom line and basis for a great boarder. The BFN is not the best boarding boat but hanging out with BuffaloBFN on a weekend he had a kid who was throwing insane inverts off the back of the Pumpkin with no extra weight added what-so-ever. Just 4-5 people in the boat and this guy was getting some huge air. Greg had driven for him coutless times behind his boat so the guy knew what he was doing.
So .......why the long post? You don't need no stinking wakeplate to add to the boat. Just add more weight.
The platform bolts are lags!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 5:22pm
Actually, trying to stay away from weight. People OK, fat-sacs maybe, lead no way. If something was to happen. People are close to neutrally buoyant, water is water in the boat or outside it, lead is just wrong. I've been in boats leaded out.
In aircraft we always think about strength to weight = crash worthiness. In ski boats lead = stress cracks.
A wake modifying plate won't add 5 lbs.
PS - Would you use 5200 to reseal the lag bolts. I need to seal the hardware on the transom. Since last year I've been trying to stop a small leak coming down the starboard side into the bilge. I took the exhaust apart and resealed the mufflers with epoxy (very tiny pinholes) and reclamped everything with good t-bolt clamps. Still have a small leak.
PSS Foot, will you make it to White Lake this year? If so maybe you could drag the Buffalo with ya!
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 7:42pm
Andy, unless the goal is to make the wake rampier and slightly smaller, I dont think a wake plate will do what you want.
BTW, I would not consider adding a plate to either side... I'd do something narrow in the center (padded keel). That would give you plenty of ability to alter the boat's attitude (bow up/down) which is the primary function of the plate. Putting them on the sides may alter the rooster/wake shape more, which Im guessing you dont want to do... the 2001 throws a nicely shaped wake.
Yes on the 5200 with the platform brackets and bolts. That is what I used for both the Tique and BFN platforms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 9:13pm
Yep, small maybe 14in. wide X 8/10in. between the two middle platform brackets. This is on the big side, I think.
It could have a 3 piece lip on it(wicker bill) so all 3 pieces would adjust independently and be 5/8 wide X 4in long and the whole thing have 4 settings- 1)up & stowed. 2)flat in plain with the hull. 3)the aft edge 1in. down. 4) aft edge 1-3/4 in down. - All dimensions subject to fudging here & there.
Just seat of the pants. I think with it flat,the center & starboard lips flat and the port 1/4in down the wakes should be equal and have a little better shape from side to side at 20 mph. With only the driver in the boat.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 9:43pm
Andy, you might have to draw me a picture of what youre envisioning... I cant work it out with the shape of the 2001 hull.
If youre just trying to even the boat side to side, a little bit of counter weight added to the port side is probably the way to go. I dont think it would take much. 50 lbs, maybe less?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2014 at 11:25pm
The pictures Adam posted at the top of the page is similar. Not as long fore to aft with a tunable aft edge. The mount on the boat would be much wider than the plate so no extra holes in the boat. The plate itself maybe just a little wider than the pad on the back of the hull,
it might be to wide at first then trimmed to be just as wide as the pad on the hull.
At one time I carried a 25lb vinyl coated mushroom anchor wedged between the passenger seat and the hull.
Messing around I made a hard turn (forgot it was there) it came across the boat missed my left foot - BUT if it didn't hit my right foot it would have probably at least cracked the hull.
Now I have 9 screws and a titanium plate in the starboard foot.
Man that hurt. Ya know I don't have one tattoo, but I do have more than my share of scars & stitches.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2014 at 1:11pm
   Actually, trying to stay away from weight. People OK, fat-sacs maybe, lead no way. If something was to happen. lead is just wrong.
Unless you're planning on going out in the ocean or boarding in 3 foot surfs then having lead weight in the boat shouldn't be a problem. Do I think my buddy went overboard? Yes; I do, but it's his boat and he's the one wearing braces everywhere. His boat looks almost as good as mine except the interior just because he uses his waaaaaaaay more than I do and he is probably the most anal guy I have seen when it comes to his boat. I haven't seen ANY sign of stress cracks in the gel or anything and he's close to 3k on the hobbs meter. The 176 lbs of lead I use are two 88lb bricks than came off the nose of a 727. I put antiskid tape on the bottom so they don't slide ANYWHERE even in high speed turns. But I am aware of that when they're in there when in use and drive accordingly.
A wake plate won't add 5lbs of weight but what's the force/lbs it's generating on the hull that wasn't designed for it? By putting a large sac in the stern you can change the shape and size of the wake by the amount of water is in it.
Not sure about the White Lake thing... May try to make it but it depends on if I have my girls that weekend. I'd come boatless if I do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2014 at 10:23am
Mornin' Tim,
Once in a while I do get surprised by a rouge wake from another boat, and I have taken a couple over the windshield.
I guess everyone has.
I'm looking to improve the wakeboarding wake without adding weight. I know it won't be much but I there is a little room for tuning - I think?   The water ballast at least absorbs shock some. I'm not opposed to 4 or 5 five gallon plastic square containers.
platform rackets.
Take scrap a/c composite panel and drop it just 1 foot on the floor, then tape one of the 88 lb. lead weights to it and do the same thing.
That happens over and over again in a day on the lake..
Anyway, as I was GI ing the toon, found some rotten flooring so now I'm rippnig that apart. So this on the back burner. (for now)
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2014 at 1:08pm
Mornin' Tim,
BFN?
1988 BFN-sold
