What is a good bilge pump for my Mustang? |
dangerwil
Senior Member Joined: June-20-2013 Location: Orange Park, FL Status: Offline Points: 319 |
Posted: March-31-2014 at 3:04pm |
It's about time to install the pad for the bilge pump. So I need to buy one and get the dimensions of the base. Some better than others? What gallon per hour?
Thanks! Bill |
chuckactor
Senior Member Joined: August-20-2013 Location: Ft Collins CO Status: Offline Points: 102 |
Really depends what you want the pump to do. Do you want to get out excess water or do you want to keep the boat off the bottom of the lake? My last boating experience was all saltwater in Florida. The guru on all things boating at the time was a surveyer on the east coat of Florida named Pascoe. He wrote a number of very honest boat reviews and boating articles based on his many years of surveying. Here is his take on bilge pump sizing.
http://marinesurvey.com/yacht/bilge_pumps.htm It may seem like a total overkill but it's what is really required in real life if something goes wrong. Chuck |
gR@HaM
Platinum Member Joined: May-01-2012 Location: UK Status: Offline Points: 1265 |
link doesnt work..
Im paranoid of losing the shaft (even with a safety collar) or rudder, so went for the rule automatic 1100gph. It will empty a bucket in seconds! |
'82 Ski Tique
gR@HaM
'82 Ski Tique
Bill, This is a very important question. Even the biggest pump will not keep a boat off the bottom if you have a major issue. I had one incident where I had to beach my X55. This was before I put a new bottom on her. I through a prop blade and before I could stop it, the strut along with a chunk of the bottom went with it. I was able to tow it back home with the engine running to keep the battery charged with the pump running but had water well over the sole. |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7954 |
I like the Attwood 500 gph pump with the enclosed mechanical float. I haven't used a pad, but have glued the base to the bottom of the bilge with 5200.
forvicjr
Gold Member Joined: August-24-2012 Location: sc Status: Offline Points: 692 |
I have not one but two 800 GPH pumps on mine. No foam so extra capacity.lol.
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
dangerwil
Looking at a Rule 27S 1100 GPH. Nice to have float switch.
74Wind
An external float switch also has its advantages; should you wish to get every last drop out below the float, or should the dash switch fail, you can simply reach down and pull up the float to activate the pump.
1974 Southwind 18
1975 Century Mark II |
gR@HaM
..or the rule automatic ones run off a 3way switch so you can can just flick it to over ride
'82 Ski Tique
Graham, Considering the water you are on, I think you need one of the Rule 10000 GPH pumps!! |
gR@HaM
There was a mild frost this morning Pete that's the most wet the boat had got since I bought it!!
'82 Ski Tique
