GT40 Spring Maintenance ? |
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Posted: May-22-2014 at 8:12pm |
Hey guys, bought a new fuel filter for the FCC cylinder. Ideally should it be run first to collect the crap from the tank and changed out afterwards? I also bought that little $1.00 fuel hose that historically goes bad and causes issues.
What weight oil does the '99 GT40 take? Lastly does the air filter need to be removed and cleaned out each season? Thanks! Ken |
gun-driver
Filter - Your choice unless you run the tank dry the crap may still be in there Replace the hose when in there Same oil as any flat tappet motor You can remove the spark arrestor and spray carb cleaner through it then blow with compressed air if it looks dirty. |
