Flooring Question |
The Lake
Posted: April-18-2006 at 10:07pm |
I currently have a drop in floor section between the dog house back to the transom between the main stringers. The floor is held up between the stringers by 1x2's attached to the stringers. I have removed the 1x2's but before I reattach I want to inject resin into the screw holes in the stringers. Should I use polyester or epoxy, some other product? Once I get the 1x2's back on I'm planning on fiberglassing them in.
Bob's2001
Senior Member Joined: March-28-2005 Location: Lake Jackson TX Status: Offline Points: 241 |
I am going to use the same resin i use for glassing my floor.
Bob Ed
83 2001 |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5323 |
I think that I'd use epoxy resin. Epoxy resin is the stronger of the two.
David F
Yes, use epoxy. Not only is it stronger, but it is a superior adhesive and will bond much better than polyester resin.
The Lake
Thanks for all the help guys--as usual it's great!
