water over bow |
nedave
Newbie Joined: October-12-2010 Location: OREGON Status: Offline Points: 20 |
Posted: July-27-2014 at 9:28pm |
took water over the bow in 96 Ski Nautique with GT40 5.8 HO.
Shortly the boat died while cruising at about 3000RPM. Subsequently it would start but could not get any RPM and ran rough. Got towed in. Today I hooked a water supply to it and it started right away. Normal operating temp and oil pressure. Wonder if the water over the bow could have got into something which casued the problem but has now dried out and will be OK. Anyone else had this problem? |
TX Foilhead
Depends on how much water, if it got deep enough to get to the bottom of the crank pully the belts and pully will sling it around under the hood.
baitkiller
what he said, it can also get under the cap. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4269 |
But wait, it's a '96 Ski, how did the water over the bow get into the boat? I'd think you could ship a few gallons, but the rest would sheet off to the sides of the windshield. Am I missing something?
Also, did you bury the nose just idling into some wakes, or was it at higher speed? |
nedave
I wasn't paying attention and buried the bow into a boat swell. A wall of water cascaded in over the bow and windshield soaking the dash. I know nothing got into the motor area but was wondering if something in the dash could have gotten wet and caused my problem.
It seems to run fine now(sitting in my driveway) but I'm concerned how it will be under load. |
63 Skier
I don't know what under the dash would cause you to sputter and not build rpm. I could see it now starting and running at all, but sounds like it continued to run. So, not sure what happened.
If it runs fine on the hose, I'm betting it will run fine on the water. |
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Is it possible to have a short in the ignition wire in the bilge? It got wet and robbed voltage for a while......?
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
