  New Posts New Posts RSS Feed - check valve on cooling system
Dawg2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawg2001 Quote  Post ReplyReply Direct Link To This Post Topic: check valve on cooling system
    Posted: September-08-2014 at 2:59pm
1985 ski nautique 2001. Is there a check valve on the cooling system? The reason I ask is that for my "fake a lake" I have always stuck a garden hose into my strainer basket and this has worked fine for years. It has always overflowed into bilge until start-up and then it would suck down a little. Now it runs out of the water pickup on the bottom of the boat. It would make sense to have a check valve to "hold" the cooling water in the system during an engine shut off. But I can't find any reference of a check valve in the forums.
Does anyone know if there is a check valve between the pickup and the strainer basket?
85 SN2001 Will Rogers said: "I'm not affiliated with any organized political party, I'm a Democrat."
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2014 at 3:58pm
No check valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawg2001 Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2014 at 4:05pm
Wonder why it would start flowing back thru the pickup? Better question might be why didn't it before? I had a leak on my transmission cooler so I removed it and fixed the leak and then hooked everything back up. That is when it started flowing back to the pickup instead of overflowing out of the strainer. Weird. So now I am worried that sticking a garden hose into the strainer will not provide enough volume to cool engine in backyard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2014 at 4:24pm
There are better and safer ways to run your engine in the backyard.
cmacbuck69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmacbuck69 Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2014 at 11:21pm
You should clamp your garden hose to the engine side of the strainer basket cooling hose when running up out of the water. When the engine turns on the water pump pulls water into the engine right away so there is no need to store water in the engine during shut down.
