Gauge box for 1987 Nautique |
mrcdeuce
Newbie Joined: September-21-2012 Location: Minocqua, Wi Status: Offline Points: 6 |
Posted: September-08-2014 at 11:26pm |
Have a 1987 Ski Nautique 2001. When I push the nav lights the rest of the gauges fludder. The local dealer says I need a new "GAUGE BOX" and they cannot order one. Is one available and how much?
Thanks, Mark mrcdeuce@yahoo.com 715-892-7166 |
Bri892001
That sounds like a pretty classic low voltage problem to me.
There's no such thing as a gauge box on an 87. Some of them had alarm modules, but that doesn't even come into play here, and wouldn't help your problem. You'll want to add a new ground wire from either the battery or the engine block. Then, have that wire go to a bus bar, and tie in all your grounds to that bus bar. Or, if there is a ground bus (or ground strip as it's called in the schematic) already there, just run your new ground wire from your engine to it. Then, you're going to want to run a new, (in parallel with the original or replacing it) hot feed from either the fused side of the engine breaker, or the battery positive. If you use the battery positive, you'll need to fuse it. Check out the 87 wiring schematic from our reference section: http://www.correctcraftfan.com/downloads/1987_dash.pdf Also, check this thread on re-enforcing wiring, the 93 is a little different layout but the principal is the same: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21901&PN=1&title=added-new-dash-ground-to-93-with-pics |
Hollywood
Step 3, lose that dealers phone number.
