  New Posts New Posts RSS Feed - Gas Lead Substitute
Gas Lead Substitute
Lakeview View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lakeview Quote  Post ReplyReply Direct Link To This Post Topic: Gas Lead Substitute
    Posted: May-08-2015 at 9:53am
Pulling the 67 Barracuda out of mothballs to run this summer.My concern is the 318 Fury(chrysler) ,cautions the use of leaded gasoline.Anyone use the many lead substitues on the market?,and do they work? Thanks
Lakeview
1992 Barefoot Nautique
1967 Barracuda SS
1967 Chris Craft Cavalier
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 9:57am
Don't waste your money on it. It takes a long time for the seats to wear out.    By then you will have saved enough money (from not buying that stuff) to rebuild the heads with hardenend seats.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 10:08am
^^^ I'd agree. Dads the original owner of his '75 Waukesha. He always ran lead substitute religously up until ~15 years ago. 15 years later it's still as strong as a 40 year old original motor can be.
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 10:39am
We used it for years in the 64, but then had the heads re-built. Not sure if it really had all that much impact.
Definitely make sure you get an oil with ZDDP content higher then 1200 ppm. I guess, I am just assuming your going to change the oil - HA!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lakeview Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 10:56am
Thanks for the input-yes oil will be addressed.
Lakeview
1967 Barracuda SS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 7:35pm
Jim,
I agree with all the rest. It's a waste of money. Save the money for when the time comes to do a top end job on it. Did you know Billy Mays used to hark the stuff? Is someone trying to push the stuff on you???
BTW, do you remember the marine white gas? Do you know what it was? It was straight run gas with absolutely NO additives! The stuff NEVER hurt any of our old antique and classic engines! Hopefully you aren't wasting money putting the junk in the Cavalier???
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 9:41pm
There are some great deals on lead substitute at AutoZone.
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2015 at 10:36pm
Jeff,
You made my day. In fact, more so my whole weekend. I'll be over at my favorite Autozone in the morning when it opens!! I hope they saved the box so I can get the case price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2015 at 3:21am
I use Lucas Oil's "Fuel Treatment" and find it to be great stuff. From their website: Lucas Fuel Treatment should definitely be used in vehicles that require leaded fuel because it actually replaces the benefits of lead in gasoline without causing harmful emissions.
Marvel Mystery Oil also works as an upper cylinder lubricant when mixed with gasoline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lakeview Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2015 at 9:15am
Appreciate the input-NO Pete haven't been sucked into the "snake oil" sales pitch-I am a firm believer in Marvel mystery oil and good old STP.Between the ethanol and lack of lead in good old gasoline, I am going to try and locate a source for racing fuel in my area.
Lakeview
1967 Barracuda SS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2015 at 1:12pm
Jim,
Are you planning on running the racing in the Cavalier too? Which model and what engine is in it?
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2015 at 3:40pm
Jim,
100ll from the airport, it's cheaper than race gas and stays good forever. It also takes care of the lead substitute issue
