Cam and Valve Spring Question |
Jeremiah2001
Newbie Joined: April-16-2012 Location: Tennessee Status: Offline Points: 29 |
Posted: June-05-2015 at 12:50am |
In the middle of a 351W engine rebuild. Of course I couldn't leave well enough alone.
My head were cracked so I found a set of rebuilt GT40P heads. They came with a set of new trick flow valve springs # TFS-2500100. Seat Pressure 115 @ 1.800 Open Pressure 315 @ 1.200 Max lift of .540 Ive also ordered a Cam Research Ski Cam which I believe has the following specs. intake lift .49 exhaust lift .49 intake duration 278 exhaust duration 282 Intake duration @.050 216 Exhaust duration @ .050 220 lobe separation 112 recommended seat pressure 95lb recommended open pressure 295lb I'm a novice but It appears the valve springs have a higher rating than recommended by the cam card. Will these work? Of course I will call Cam Research but you guys are wizards so what do you think? Thanks Jeremiah |
oldcuda
Senior Member Joined: June-22-2010 Status: Offline Points: 474 |
Is that a flat tappet cam? If so that's a bit too much spring pressure.Don't forget to use the proper oil for break-in NOT the additives.
mamigacz
Groupie Joined: June-08-2014 Location: Wisconsin Status: Offline Points: 96 |
I my opinion, that spring would be a good fit for that cam. With a .49” lift you are only get an open height of 1.31” (1.8” - .49”). At 1.31” you will get an open pressure of 280lb. I can show you the math if you want.
Too much open pressure is hard on the cam. Too little open pressure and you might experience valve float. Your only 6% less than the recommended open pressure (280lb vs 295lb). If you were zinging this engine past 6000 RPM you might have a valve float issue. But you are going to be maxing out around 5000 PRM. Also, being a little high on the seat pressure (115lb vs 95lb) is better than being low. The next thing is to make sure the installed height of the springs is 1.8” Are you using the stock GT40P valves? If you are, pay close attention to the exhaust install height. I remember having to buy special keepers that raised the install height. |
mamigacz
I found this article from hot rod magazine, which explains the exhaust valves on the GT40P heads.
hot rod mag article If you have to buy a bunch of parts to make these trick flow springs work, it might be worth while to buy a new set of springs from cam research. I wish I would of. I think the spring kit was $100 three years ago. |
Jeremiah2001
Thanks Everyone for the replies. I called cam research with the specs.
They believe these will work just fine. They suggested I have the machine shop double check the pressure of the springs just to make sure. |
