  New Posts New Posts RSS Feed - Condensation on EXTERIOR of gas tank
sstichter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sstichter Quote  Post ReplyReply Direct Link To This Post Topic: Condensation on EXTERIOR of gas tank
    Posted: July-30-2015 at 6:58pm
Can anyone advise on the fact there is condensation dripping from the exterior of the gas tank. The floor under both sides of the tank is quite wet. Oh, maybe the condensation is coming from the wet floor... huh. Why is the floor under and behind both sides of the gas tank wet?
I read the posts about the speedos and pitots. I don't think these are the problem. I put 5200 around the rudder housing because there was a slow drip from there.
What would cause condensation from the outside of the metal gas tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2015 at 8:10pm
Cold gas pumped in on a humid day. Same as a cold beer sweating on a humid day.
You put 5200 "around" or under the rudder port? How's the rudder port packing? Do check the pitot tubing and the dampers. Regulated air under 30 will do it to find any leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2015 at 10:32am
If the problem is wet carpet start with wet carpet, not an assumption of a condensating gas tank.
