  New Posts New Posts RSS Feed - 1988 STRUT BUSHING
1988 STRUT BUSHING
D&C1988 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D&C1988 Quote  Post ReplyReply Direct Link To This Post Topic: 1988 STRUT BUSHING
    Posted: August-06-2015 at 2:49pm
Zach, this is for you. Your name seems to come up here alot. I can not find a single shop with in 50 miles of St.louis that will do the replacemnt of the bushing, let alone give me a not to exceed price for the job. I travel through Indy a couple times a year on my way to North Webster / Warsaw / Tippie. Anything you can do ???
Thanks
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 3:04pm
I don't mean to take business from Zach but 90% all of FL sends their struts to Admiral in Tampa. Just a few weeks ago they quoted me I believe $125 to remove, supply and install a rubber bushing. The norm here is to stick it in a "it fits, it ships" box with a return label.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 3:05pm
David it's not that hard to do yourself if you have any mechanical ability. Many here have done it themselves using a long threaded rod and a deep well socket if you don't have access to a bearing press. Some have simply used a deep well socket and a hammer to drive out the old one. It's not too difficult of a job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D&C1988 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 3:22pm
I have though about making the attempt. I even bought the brass/rubber shaft bushing.
I have a prop puller and can get that off. Just not sure how to drive the old one out with the shaft in place. I saw the newer $400 tool but not spending that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 3:35pm
For what's it's worth, I bought the XPC bushing for $80. I spent 4 hours beating and cutting the old bushing out 1/4" fragment at a time. I spent twenty minutes putting the new one in. My 4.5 hours is worth more than $45. Next time I'm sending it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 3:44pm
You need to either pull the strut or the shaft in order to replace the bushing. Realigning the strut to the log is a bigger job than pullin the shaft.
Getting the old bushing out of the strut can be a pain. Putting the new ones in is easy.
I would expect any competent shop to also do an alignment as part of the job. Probably not cheap to farm out.
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 4:21pm
The Cutless bearing is not that hard to remove and reinstall.
set screws and you can use slide hammer to pull it out. install new one by freezing new one and pressing into the strut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D&C1988 Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2015 at 5:02pm
So does any one have one of these???
No strut removal OR shaft removal.
I'll rent it
http://www.strutpro.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2015 at 3:19pm
It's my opinion that the strutpro is not worth the investment. Getting the old cutlass out of the strut isn't that big of a problem. With A Sawsall or even a hack saw with the blade through the bore, cut the brass shell. This will allow the shell to be loose in the strut. Use the new cutlass with the threaded rod to press in the new while pressing out the old cutlass.
