  New Posts New Posts RSS Feed - converting to electronic ignition
yanivsai View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yanivsai Quote  Post ReplyReply Direct Link To This Post Topic: converting to electronic ignition
    Posted: May-30-2006 at 7:06am
hello boys
i have 1982 sn,how can i know what dist' i have,left or right ?
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2006 at 8:32am
RH if it's a stock motor and has been replace with a conventional model, look for a tag or number stamped into the house below the cab on the outside, and if you got the cash replace the whole dist with a mallory YLM-554-CV or YLU-554-CV. Mallory has just started to renumber there marine line of parts but summit racing still has the older numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote yanivsai Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2006 at 9:10am
thanks chris
i read the mallory ylm\ylu specification and it looks good,but both of them are Counterclockwise so whats the difference ?
are they better then electronic ?
if my ang is Rh so the dist' is Counterclockwise ?
thanks
yaniv
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2006 at 9:33am
it doesn't matter on the rotation a std or rev rotation engine both spin CCW. and they are both electronic, the YLM is cheaper and uses a magnetic pick-up and the YLU uses an optical pick-up and both will be much more reliable than a conversion kit.
