71 Mustang Pick Water Pick Up Line Size |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Posted: December-04-2015 at 12:44pm |
I am headed to the lake today and want to pick up the materials (before getting to the lake) to install the Timmy T in the Mustang. Does anyone know off hand the size of the water pick up lines?
I am considering installing the T's and then putting together a siamese (wye) type line for use with the bucket for winterization. Thoughts? |
'88 BFN |
Morfoot
Greg the few times I've run the 72 on dry land All I did was remove the hose from the water pickup fitting and stick the male end of the water hose from the house in the cooling hose and use the worm clamp to secure it........ Works GREAT and takes about 30 seconds to do it. The mustang hose should be long enough to attach to your bucket if your using the bucket method.
my $.02. |
Thanks(1)
<5sec with the tee, Tim... No hose clamps to mess with or knuckles to bust open getting the hose off the fitting!
The line size differed between marinizers, Greg- not sure which size HM used. For the extra $2, I'd pick up tees in both 1" and 1-1/4". |
Mine is 1" but it's the older cooling system
NCH20SKIER
1" on the 71. Another "Timmy Tee" installed.
Mine had the double water pick up, the port side simply "looped back" to the starboard pick up and connected with a tee. |
'88 BFN |
Good deal. The dual pick ups are typical of all boats of that era. I suspect the du impeller chryslers can use the extra flow the 2nd pick up provides. All my fords are looped like you describe.
Please remit Timmy T license fee to Timmy Tee, c/o CQ P.O. 69, Deep Lake, Illinois or Wisconsin
