Moving Nautique 200 engine box |
utahdave
Groupie Joined: April-06-2013 Location: Washington, UT Status: Offline Points: 51 |
Posted: February-19-2016 at 4:01pm |
The box that covers the engine in the Nautique 200 doesn't have much extra clearance room at the bow and stern ends of it. Removing the whole box (reach hoses/maintenance) and re-installing it is much more difficult for 1 person than it was in my 1999 SN. With the 200, you have to lift it evenly and straight up.
With 2 people, it works well. Unfortunately, I don't always have access to a second person. Has anyone out there worked out a system to make this easier? I thought about clamping something onto the pylon to support one end and facilitate controlled lowering of a few inches at a time. Thanks, Dave |
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
How often are you removing the engine?
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
utahdave
I haven't removed the engine at all.
Access to the hoses and clamps for winterizing (closed cooling with raw water to trans oil cooler, oil cooler, heat exchanger) is much easier if I pick up the entire engine box and move it. I have been skiing this winter, so I have moved the engine box to winterize 3 times. Dave |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
Ha! I was just going to describe using a few straps over the ceiling beam....your solution is way better
