  New Posts New Posts RSS Feed - Fixing Damaged Floor
td_in_nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Topic: Fixing Damaged Floor
    Posted: February-20-2016 at 7:44pm
I am looking for suggestions on how to repair a damaged floor. It is not wood, it is fiberglass board which has some type of foam in the middle. Basically a layer of fiberglass 3/8" thick foam and then another layer of foam. I think the PO dropped something heavy on it and it has a small deflection when you step on it, I am replacing the carpet so I want to repair the area which is 18" long by 7" wide.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2016 at 7:56pm
Looks like you are already moving the right direction. Cut out the damaged area. Taper the edges. Layup w/ epoxy resin/eglass, build up each layer w/with increasing perimeter.
I see you are using an osc tool, I find those quite useful
Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2016 at 8:19pm
I am hoping to do the repair this weekend, is there any place that would have the supplies?   I have a west marine and overtons near me, just not sure which one works well and where to get reinforced fiberglass.   Their websites are not that helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 7:49am
Tom,
I feel West would have a better supply of cloth and resins. They should also have smaller sizes of the resins/hardeners however, I'd suggest getting more than you need. You'll find having the epoxy around will be handy for other projects even if they aren't boat related. Get the metering pumps too.
Chris,
I too have found the osc very handy. I bought a Fein years ago before their patent ran out and everyone else started making them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 9:28am
Thanks for the advice guys. I will post some pics when I am done.
I find the osc very handy indeed..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 9:54am
Too bad you weren't a little closer Tom..... I've got tons of honeycomb sandwiched fiberglass floor panels lying round.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 10:01am
Tom,
Keep us informed and do post some pictures of the progress.
BTW, unless you're looking to purchase a tube, I wouldn't even consider going into an Overton's!
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2016 at 6:44pm
You might find a video like this useful:
TAP Plastics You Tube Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2016 at 11:03am
As always thanks for the great advice. The floor is fixed (will post some pics this weekend). As I am getting ready to install the carpet I am trying to figure out what to do with the existing holes in the floor for dog house hardware, seat etc. should I just try to reuse (guessing they will be difficult to locate once carpet is in) or should I fill them in with epoxy and drill new ones when ready. It is a fiberglass floor with foam between the top and bottom layers.
Btw did find a good use for the overtones gift card someone gave me as a present - I bought a slalom ski bag for my son's new HO TX ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2016 at 11:37am
Tom,
I'd fill the holes and then re drill new ones. You may or may not be able to find the old ones depending on how thick the carpet is but, chances are high that the factory put them in in the wrong place anyway! After you drill the new holes, seal them up with some 4200 when you drive the screws in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2016 at 10:12am
Here is a pic of the repair.
I had a difficult time finding filler material to replace the old foam. The best I could find was the high density stuff at Lowes used as house insulation. I had a issue because it was not the same thickness as the original so I had to shave it down. Once I got the layers of fiberglass on, I drilled several holes into the repair area just large enough to insert the tube from a spray can of foam,   I sprayed in a small amount of "foam in a can" for fill any voids then put two layers of fiberglass to seal up the holes.
In my discussion with a marine carpet installer he gave me a tip about some adhesive remover for removing difficult carpet. I was having a hard time with one piece of carpet on a seat base. The product was Sentinal 626 - it worked great! It looks like they make something specific for outdoor carpet 747, but the shop I went to did not carry it,
Any ideas where I can get some of the hardware for the doghouse base (the ones on the inside of the base which attach the base to the floor and hold it in place)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2016 at 10:24am
Tom,
If you need to do this again and don't have any filler material left over, I would suggest going all foam. The Great Stuff density can handle to load just like the original with the glass on top. Fill the hole with the foam, quickly lay a piece of plastic wrap over it, put a piece of plywood over the plastic and then a weight such as a CMU (concrete block). If any excess foam oozes out, it can be trimmed after it's cured.
Great tip on the adhesive remover. Many have fought the adhesive!! Does it work for both a solvent base and a water modified adhesive?
Have you looked at Christine's for the dog house hardware? I wish I could picture what it is.
The repair is looking great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2016 at 10:38am
I will check with Christines, .
The shop I bought the adhesive remover from was not sure if the 626 would work well on the boat carpet, adhesive but I thought I would give it a shot. Glad I did as I could not move the carpet at all, Once I used this stuff it peeled right off.
From the website: 626 Carpet & Sheet Vinyl Adhesive Remover
SENTINEL 626 CARPET & SHEET VINYL ADHESIVE REMOVER is a powerful, biodegradable, formulation designed specifically for quickly removing latex, acrylic, and pressure-sensitive adhesives from concrete, terrazzo, ceramic, and vinyl tile or wood substrates. Use 626 to remove tan or beige colored glues, linoleum backing and vinyl sheet goods adhesives. 626 cleans up with water, is non-hazardous, and requires no dilution, so it's ready to use.
I would have preferred to use the 747 but they did not carry it. link to website Sentinal
