Stuck Manifold bolt solution |
mbshaw88
Senior Member Joined: April-28-2013 Location: Chicago Status: Offline Points: 244 |
Thanks(1)
Posted: April-27-2016 at 4:28pm |
Bolt was rusted to the manifold and the hex was completely rounded out after multiple attempts. I decided to make it my bitch!
ground a steel rod to fit inside the hex recess, welded it to the bolt, and a nut welded to the end. One zap with an impact wrench and she was free. Engines are so much easier to work on when they are on a pallet on a welding table . |
Duane in Indy
Removed many that way. The heat of welding does as much as anything. Like your "Kant Twist" clamps too.
1978 Mustang (modified) |
Duane, Matt must have borrowed them from a tool and die maker!! |
shierh
i had a rusted head bolt that was so bad it was completely deformed. I got a pin type socket and removed it with ease.
HondaF1
Newbie Joined: August-03-2015 Location: PA Status: Offline Points: 20 |
have removed a bunch of these on my gt40. I like the idea but I am concerned with mig welding on EFI engine. Any input would be appreciate.
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
I always unplug the ECU and battery when welding on car or boat
MrMcD
An alternative used by the tear down guys in Engine Shops to remove stuck bolts and plugs. The engine must be drained of coolant. Take a torch and heat the area around the bolt you want to remove. Hit the area while very hot with a little wax. Let the torch pull the wax into the threads just like plumbers do when soldering copper pipe.
The wax will let you spin the stuck;/rusted bolt right out. Just like with copper pipes when you do this there can't be any moisture or it will not work. |
