  New Posts New Posts RSS Feed - Cooling hose size?
Cooling hose size?
jblunceford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblunceford Quote  Post ReplyReply Direct Link To This Post Topic: Cooling hose size?
    Posted: May-10-2016 at 2:08pm
Hoping someone can advise what the size/ID dimension of a cooling system hose on my '86 Martinique BR w/ 351.
I need to replace the long hose that comes off the bottom of the fresh water impeller housing and goes back to towards the stern to the lower end of the tranny cooler. I'm pretty sure it's a 4-ft length stick, but not sure exact diameter (ID), It should be wire reinforced in understand as its under pressure.
Also appreciate any rec on where to purchase on line...thanks in advance.
Jeff in Hoover, AL
Jeff in Hoover (Birmingham), AL
1986 CC Martinique Bow Rider 351PCM
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblunceford Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 2:09pm
Hey, I got another star....
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 2:32pm
Assuming your 351 is a PCM its 1" diameter. I buy all my hose from SkiDim as they're about the cheapest and the quickest.
1976 Ski Nautique 351 Escort
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 2:32pm
All of the smaller cooling hoses are 1" ID. The stuff pre rwp needs to be steel reinforced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblunceford Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 5:23pm
Given the location as I described in my original post, is this hose on the positive pressure side or on the suction/ negative pressure side?
spiralhelix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 6:28pm
that hose is on the negative pressure side (suction side)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblunceford Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 6:35pm
That's what someone else thought too...thanks for confirming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2016 at 6:50pm
I just put all steel reinforced in. Holds up nicely over time and it all looks the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2016 at 7:10am
Jeff,
Yes, confirming again, this is from your other post regarding the hose on the suction side of the RWP.
Jeff,
The 4' section from the trans cooler to the RWP is the suction side. I'd worry about that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblunceford Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2016 at 2:12pm
thanks for the note....yep, I can get into the weeds pretty quickly, and double confirm things...I do appreciate the feedback & assistance.
Jeff
